?? for the Dyno guy's
With all your testing and Dyno expreience w/A headed engines and the NEW A460 intake. What carb spacer IF ANY one OR type,stands out to perform better on this engine. I'm asking this because I will be buying a 2" spacer for mine in the near future to get my carb height where I want it.
My uneducated thinking would lead me to believe that different spacers will work better/worse on different intakes because of runner length,volumn, and height. I think my intake is a well designed intake and I know lots of different combos have been tested on it so I'm curious to what you have to tell me.
Re: ?? for the Dyno guy's
Rick I have an HVH super sucker and if I didn't have it I would have a Jomar taper sucker.....
the Coug- Posts : 3055
Jomar with 3 cut taper
The one inch Jomar power cone spacers make more power than no spacer or a one inch open spacer . I've had some high HP engines that I though would like a 1/2" open spacer under the 1" Jomar spacer....wrong . It's best to put the carb where the engine wants it not where you want it
Lem Evans wrote:The one inch Jomar power cone spacers make more power than no spacer or a one inch open spacer . I've had some high HP engines that I though would like a 1/2" open spacer under the 1" Jomar spacer....wrong . It's best to put the carb where the engine wants it not where you want it
I understand that Lem,but i'm in a predicament w/hood clearance. W/no spacer my carb top is only 1" from the top of my 6" cowl. So i'm raising it above it and cutting out the cowl and adding a scoop on the carb. Hard to explain exactly
Use the 1" Jomar and put some kind of riser between the top of the carb and bottom of the scoop.
rmcomprandy wrote:Use the 1" Jomar and put some kind of riser between the top of the carb and bottom of the scoop.
Thats an idea
Think what I might do is just buy a pentroof single 4 top for my TFS TR and it should be about right
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» dyno next week any hp guess's ///rod picture damage and dyno sheet added
» TRYING to shut my chevy friends
» Will your Dyno do this.
» 2009 EMC Motors
» 2009 EMC Motors
