hey ranger guys i need some help
Fat Fender 460
what do you guys do to fit the exhaust down in your rangers when you install a 460. I put a front frame section of a ranger in my 55 f100 and i cant mount the motor because the exhaust wont fit down in the frame. i can squeeze it down in there with out the passenger manifold on the motor but it looks like lots of cutting and plating on the new frame to get the manifold to fit in there. help please!!!!!!!!!!!!!! Is there any stock manifolds that i can get down in there to work. thanks
Fat Fender 460- Posts : 45
Re: hey ranger guys i need some help
Thay had to make thiers and run them on the out side of frame
res0rli9- BBF CONTRIBUTOR
John, If you can get it down in there ,I can bend some pipe for ya
Where do the manifolds exit out on the ones you have
I had to use fenderwell headers that I built. I took one look at how close the motor was to the frame and knew they had to go out the fenderwells.
BigBlockRanger- Posts : 1267
When I had Exhaust manifolds on my 84 Ranger, I had to notch the passengerside frame rail. Then I built fenderwell headers for it.
501ranger- Posts : 54
501ranger wrote:When I had Exhaust manifolds on my 84 Ranger, I had to notch the passengerside frame rail. Then I built fenderwell headers for it.
Thats the best thing to do imo
bbf-falcon wrote:501ranger wrote:When I had Exhaust manifolds on my 84 Ranger, I had to notch the passengerside frame rail. Then I built fenderwell headers for it.
X2, build the headers and get it over with
Nevs- BBF CONTRIBUTOR
Here is how I did mine the is a 2000 ranger you motor will be closer to the front than mine.here is whee i bought my header kit from http://www.speedwaymotors.com/429-460-B-B-Ford-Header-Kit,37279.html
bbf-falcon wrote:John, If you can get it down in there ,I can bend some pipe for ya
i might take you up on that pipe bending for now. i will work on it tomorrow night and notch the frame and re-plate the frame where i have to do the cutting for now. the passenger side flare out toward the back, if it tucked in like the driver side it would fit just fine, oh well thats what makes it custom right. nothing a little time and a cut-off wheel wont take care of. Thanks Rick
If it is a cruiser, you might think hard about just making a set of tri-y's or a set of log headers. They would be easier than full 4 tube headers to build.
BigBlockRanger wrote:If it is a cruiser, you might think hard about just making a set of tri-y's or a set of log headers. They would be easier than full 4 tube headers to build.
I'm building it just as a rat rod for the summer, to get out in and burn a little rubber and maybe out run the wife in her stang. probably some thing functional for now and bigger and better later. thanks for the info
John, I have some idea's. Give me a call
» v8 ranger c4
» NEED HELP! 83 ranger to 460 / c6 set up
» Jim's Little 460 AND 2000 RANGER
» The 3.0L is out of the ranger!
» intro manofmerc
» intro manofmerc
