Carb to Hood clearance ?
+15
511Fox
Barney
longroofracer
KY JELLY
56Tbird
deliveredfast
IcallhimGeorge
PRO SYSTEMS
19 posters
Carb to Hood clearance ? - Page 2 Empty Re: Carb to Hood clearance ?
Post  69F100 January 18th 2010, 7:48 pm
pics gone
Last edited by 69F100 on March 22nd 2010, 6:10 pm; edited 3 times in total (Reason for editing : pics gone)
Post  bruno January 19th 2010, 10:10 am
that is definetly a sweet idea..... i need to see if i can lay my radiator down or just move it lower
thxs guys
http://WWW.CKRME.COM
Post  billandlori January 19th 2010, 1:32 pm
Nick, if your scoop goes right to the w/s you aren't getting any air from there. There needs to be a gap for the air to enter.
On my cowl hood, I can see leaves and things flying into the scoop even at a fairly low speed. I have a hole cut that fits close to the air cleaner.
Unless you have a pan made, your not getting any air forced in there, your just gaining hood clearance.
Bill
Post  bruno March 22nd 2010, 3:25 pm
well i started designing my own scoop , i will keep everyone updated with the progress ........
Carb to Hood clearance ? - Page 2 SBC008
Carb to Hood clearance ? - Page 2 SBC009
Post  richter69 March 22nd 2010, 6:00 pm
Not so sure how much that will help..............be sure you put some sort of screen over the cabr now as all the rocks and stuff can get slung in there...............
Post  69F100 March 22nd 2010, 6:20 pm
Nick here is the one Rick and me built for his after he put the 2 4s on it
Carb to Hood clearance ? - Page 2 02-10-10_1837
Carb to Hood clearance ? - Page 2 02-10-10_1740
Post  DILLIGASDAVE March 22nd 2010, 6:35 pm
richter69 wrote:Not so sure how much that will help....
Jon makes a good point.
That proposed opening size (although decently wide) might not be tall enough IF the air approaching it (running up the curved cowl) creates a tumbling boundary layer of at the opening forcing the bulk of the rest of the air up-over the top of the opening. If the top of the new opening stays where it's at you might have to lower the bottom side of the opening down into the cowl surface to increase the height of the opening (without increasing the height of the scoop it's self).
Post  bbf-falcon March 22nd 2010, 6:49 pm
69F100 wrote:Nick here is the one Rick and me built for his after he put the 2 4s on it
affraid scratch pale
Post  KY JELLY March 22nd 2010, 7:53 pm
I think a scoop kinda like the svo mustang had would look good on a cal hood.
You can make a "plug" out of expanding foam and cardboard and sand it to your desired "shape" to fit the hole you cut in your hood and then build a fiberglass mold of the plug to lay out your scoop in.
That way you can make a flange to fiberglass it too your hood from the bottom side and it will fit your hole tightly.
Carb to Hood clearance ? - Page 2 Svo-mustang
Carb to Hood clearance ? - Page 2 85_MustangSVO_Pic1
KY JELLY
KY JELLY
Post  bbf-falcon March 22nd 2010, 8:20 pm
That's a good idea Randy Smile
Post  bruno March 22nd 2010, 9:10 pm
im sure i can double the opening (height) if i notch the hood in the other direction ....just tring to achive a clean look also ...... but i guess i can achive the look of the svo hood if i give it a "v" shape
almost like the inset on these factory hoods
Carb to Hood clearance ? - Page 2 03HoodScoop
Carb to Hood clearance ? - Page 2 97L468std
Post  TravisRice March 22nd 2010, 10:05 pm
Nick, what about grafting a Boss9 scoop to blend in with the cowl hood. Maybe keep the slope of the cowl, slide the Boss 9 scoop forward slightly to create the recess you are talking about. Just a thought.
Travis
+++++++Guess I should have started back a page, looks like thats what you are tryig to do +++++++++++++
Post  longroofracer March 22nd 2010, 10:45 pm
If you are using an air pan, is there any reason not to add a scoop to the side of your cowl hood... kind of like what the Grabber Mavericks/Comet GTs did in the early 70s...?
http://we-insurance.changeip.net/media/2009/07/2009072709410864.jpg
Last edited by longroofracer on March 22nd 2010, 10:47 pm; edited 1 time in total (Reason for editing : spelling)
longroofracer
longroofracer
Post  DILLIGASDAVE March 23rd 2010, 5:27 am
DILLIGASDAVE wrote:you might have to lower the bottom side of the opening down into the cowl surface
Something like one of these.
Carb to Hood clearance ? - Page 2 Allscoop1
Last edited by DILLIGASDAVE on March 23rd 2010, 5:32 am; edited 1 time in total (Reason for editing : sPEeeLLinG)
Post  bruno March 25th 2010, 10:21 am
richter69 wrote:Not so sure how much that will help..............be sure you put some sort of screen over the cabr now as all the rocks and stuff can get slung in there...............
its gotta do more good for the carb then the way it sits now .....i would think ..........
Post  bruno March 25th 2010, 10:22 am
thanks Dave ...i was trying to do that with photobucket .....
Post  Barney March 25th 2010, 11:31 am
Im selling my hood and harwood scoop if your interested.
Barney
Barney
Carb to Hood clearance ? - Page 2 Empty Pro-Stock Hood with Cobra Type Turkey Pan
Post  511Fox March 25th 2010, 12:15 pm
How about this idea a 5-7" tall Pro-Stock hood scoop with a Cobra type turkey pan.
511Fox
Post  bruno March 28th 2010, 7:55 pm
i found this formula on www.landracing.com
Here we GO!
The underlying question of sizing a scoop is how small can I make it and still feed the engine. Smallness is required because drag becomes prominent when speeds go up and air spills around the scoop opening because it is larger than needs to be. This added drag reduces the top speed of the vehicle. The foundation equation is not difficult and is easily solved.
EQUATIONS
CFM = (Displacement (cubic inches) * Volumetric Efficiency * RPM) / ( Speed (mph) * 2 * 1728 * 60 * 1.467)
CFM(cubic feet per minute) is not a useful parameter in scoop size although it does give you an indication of how much air you are pumping and is a great starting plce for figuring carburetor (jeeze, did I spell that right?). Remember also that the volumetric efficiency is highest at the torque peak (I think!) and can in some instances be greater than 100% because of ram tuning. My advice is that unles you have something like Dyno 2000 which can give you a volumetric efficiency number for your engine parameters, then I humbly suggest that you use 90% or 0.9 in the equation. I also assume you all know how to determine the displacement of your engine? If not, email me and I'll tell you. Awww hell, it's Disp = number of cylinders times bore times bore times 0.7854 times stroke.
CFS = CFM / (60)
CFS (cubic feet per second) divided by the target speed in feet per second gives the scoop size in square feet.
Scoop size (sq ft) = CFS / (Speed (mph) * 1.467)
But let's convert this puppy to square inches by multiplying scoop size by 144 sq inches per sq ft.
Scoop Size (sq inches) = Scoop Size (sq ft) * 144 sq inches per sq ft
Now that wasn't too hard was it? But I will combine all the above and simplify so the math gets easier.
Scoop Size (sq inches) = 0.00047338 * ( Disp * Vol Eff * RPM) / Speed (mph)
EXAMPLE
How big does a scoop need to be to supply a 369 cubic inch engine with a vehicle target speed of 240 mph. Volumetric efficiency of the engine at 8000 rpm is 90%.
Plugging into the friendly formula and find....
Scoop Size (sq inches) = 0.00047338 * (369 * 0.9 * 8000) / 240 = 5.24 square inch opening for a motor at 8000 rpm and going 240 mph.
Now what size scoop opening is needed for the acceleration phase of the speed run? Lets try the same parameters at a speed of 100 mph, WOT, same efficiency...
Scoop Size (sq inches) = 0.00047338 * (369 * 0.9 * 8000) / 100 = 12.57 square inch opening for a motor at 8000 rpm and going 100 mph.
So you can see the problem with using this as gosphel. If you build a sealed air box with the high speed opening, then you will be starving the engine for air at any speed less that the target speed! This will cause the air density going into the engine to be decreased and while the cfm going into the engine may be the same, the mass of ais isn't. This may cause an over rich condition or may even lean out the engine because of poor metering signals for the fuel flow.
This has been a serious effort to try and determine how big a scoop needs to be to meet a given speed requirement while minimizing drag. During the analysis it was found that scoop size for a given speed and engine conditions can be deterined. but that this scoop size is inadequate for slower vehicle speeds at the same given rpm. As a get off the stage commentary, I would suggest that the very best air intake system can be found on the NASCAR Winston Cup cars: the inlet is at the base of the windshield and is a very large opening. Since it is in stagnant high pressure air, ne penality is for drag is observed, plus you get a bit of a boost! I would futher comment that the scoops which have the opening against the glass but which are also very tall and further insulting the air flow problem because the high speed air over the top of the scoop is actually sucking the air from the scoop, not the other way around. Point that puppy into the wind, boys! If you use this or a similar technique or the same methodology, just remember, your milage may vary :^}.
I have been investigating the use of some 2D Computational Fluid Dynamics programs to visualize the flow in a scoop. I have found one that looks interesting, but the freebie demo only has 31 x 31 nodes for the solution matrix. I can buy the full code which has 301 by 301 nodes for a mere 300 bucks...from Japan. Maybe, I dunno...
Post  richter69 March 28th 2010, 7:58 pm
,,,,,,,,,or just buy a forward facing hoodscoop............damn it aint like your working on a space shuttle.
Post  Nevs March 28th 2010, 8:08 pm
richter69 wrote:,,,,,,,,,or just buy a forward facing hoodscoop............damn it aint like your working on a space shuttle.
Reinventing the wheel... Laughing Laughing Laughing
Post  richter69 March 28th 2010, 8:12 pm
I mean how close is it? will the damn hood not shut or what??
If you do a forward scoop get some wheelie bars and W tires................then that bitch will rock.................. Cool
Post  Larry T March 28th 2010, 9:49 pm
here is my solution you can see it in the still shots in the video,i did not know how to get the still shots in to pictures.the car went over .200 quicker and for those who want to know its a 28x10.0 non W tire. Laughing
https://www.youtube.com/watch?v=2G39Rdhutnw
Larry T
Larry T
Post  bruno April 26th 2011, 7:02 am
well here is the new hood scoop, we will jet up a couple and see how she likes it , before we spray her again
Carb to Hood clearance ? - Page 2 023-2
Carb to Hood clearance ? - Page 2 021-5
Post  95lightiningguy April 26th 2011, 5:33 pm
What scoop, j/k, looks great. Cool
95lightiningguy
95lightiningguy
