Transmission mounting Glide vs C-6
Transmission mounting Glide vs C-6 Empty Transmission mounting Glide vs C-6
Post  Tore January 20th 2010, 12:50 pm
I was wondering if anyone can help me with this. We have a car that had a glide in it now we are going to put in a C6 is the transmission mounting location the same on the on these. Or will I have to move the cross member for the tranny?
Thanks Tore
Tore
Tore
Transmission mounting Glide vs C-6 Empty Re: Transmission mounting Glide vs C-6
Post  D. Sea January 20th 2010, 1:22 pm
Tore,
You will have to move the cross member back when going from a glide to a C6.
See picture below. The cross member was originally built for a C6 and I'm now running a glide so this will give you some idea about the distance between the two mounting points.
Transmission mounting Glide vs C-6 TransMountP1010024
D. Sea
D. Sea
Post  Tore January 20th 2010, 1:41 pm
How far do you think that is Damon? Did you guys remount it on the frame or swing the crossmember back farther?
Tore
Tore
Tore
Post  BIGDOG466 January 20th 2010, 6:34 pm
Roughly 3" just put glide in mine.
BIGDOG466
BIGDOG466
Post  Tore January 22nd 2010, 5:53 pm
Tore
Tore
