Alternator mounting problems
hpwdboss1
Alternator mounting problems Empty Alternator mounting problems
Post  hpwdboss1 February 3rd 2010, 9:35 am
Will my alternator charge spinning in either direction? I would like to mount it below the crank center with the ass end pointed to the front. Crazy maybe, but really convienent if it will work.
Perry
hpwdboss1
hpwdboss1
Alternator mounting problems Empty Re: Alternator mounting problems
Post  bbf-falcon February 3rd 2010, 9:41 am
I don't think it will charge running backwards,but I could be wrong Smile
Post  billandlori February 3rd 2010, 9:56 am
I will charge OK but the fan will be turning the wrong way.
Bill
Post  John I. February 3rd 2010, 11:36 am
Yes, they don't care what direction they spin, if it's on a drag car and you don't care about the cooling, mount it backwards. Might not make that much difference anyways, as it should suck air thru instead of pushing it - not sure on that.
John I.
Post  DFI429 February 3rd 2010, 1:08 pm
Yep - alternators produce AC current, which is converted to DC by diodes. It will work in either direction with no difference other than the fan. If spinning backwards, the way the fans are made, I guess would not move air as efficiently.
DFI429
DFI429
Alternator mounting problems Empty alternator mounting
Post  hpwdboss1 February 3rd 2010, 9:39 pm
Thanks guys! I thought it would be OK but thought I'd check. Won't be running more than a few minutes at a time, so I dont think cooling should be a problem.
Perry
hpwdboss1
hpwdboss1
Post  richter69 February 3rd 2010, 11:21 pm
Seen it done many times in a drag application..................go for it.
Post  bbf-falcon February 4th 2010, 1:00 am
Learn something new everday. Not much on E/I. Smile
Post  lghting94 February 4th 2010, 9:18 am
I asked this question last year around town and maybe on the old site never got the positive answer you have so i went to Oreillys and guess what their test bench spins them backwards so yes they charge both directions.
lghting94
lghting94
