what size do i bore to
mustangjeff
71 f 150
should i bore .008 over ?
71 f 150- Posts : 3
Re: what size do i bore to
Boring a 460 .080 should be a last resort unless it is an aftermarket block. The cubic inch gain & horsepower will be very minimal & the block is junk if it gets any knicks in it from engine failure.
mustangjeff- Posts : 87
IMHO, .080 is only AFTER a sonic check verifies that there is enough metal to allow it safely.
71 f 150 wrote:should i bore .008 over ?
Wouldn't that be a hone job?
cletus66- Posts : 865
I think he meant to print .080
I think when you get to .080 that is max bore unless you sleeve the cylinders .
Jim
Jim
RetroJim- Posts : 91
You'd be absolutely amazed at the number of stock blocks that are running around at +.140 (4.500). All it takes to find ones that will go there is some searching AND a good sonic checker.
WOW , that is hard to believe that they are still holding together but I guess it all depends on what you are doing with the block . I mean daily driver , mild build or a blown enginie . I know there is a lot of meat in the block but still not sure how much is too much .
Jim
Jim
Well, the kid put 200+ passes on his 490 "seat time" motor. 4.500X3.85=490. Admittedly, there was one section at the bottom of one bore, (below ring travel) that was only .065 thick on a non thrust side...but it caused no problems. I've found a few blocks that were better than that one.
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» Which pistons/bore size???
» Head bore size limit?
» Cyl Bore ?
» Honing a Low Mileage Stock Bore Block Out to Install Std. Size Forged Pistons
» Cyl Bore ?
