Battery Cables?
+10
Diggindeeper
longroofracer
dirtbogger
14 posters
Page 2 of 2 Previous  1, 2
Battery Cables? - Page 2 Empty Re: Battery Cables?
Post  342g January 26th 2010, 9:24 pm
That is why they make wire nuts, best things since zip ties. Very Happy Very Happy
342g
342g
Post  bigjohn2007 January 26th 2010, 10:00 pm
i use lead wire and i soldier my ends and it seems to work fine for me.
bigjohn2007
bigjohn2007
Post  Diggindeeper January 27th 2010, 5:15 pm
You're basing all crimped connections assumptions on a 3 cent spade connector that you crimp with pliers?
Last time i checked a fuel pump aint high current.
The ones i'm talking about use a multiple ton press and die's to squash them. They NEVER come apart.
the connection is Positive, direct from conductor to the end.
Soldered joints are negative joints, the conductor and end never touch, and they rely on a substance that has an awfully low melting point to make a connection in a circuit that can heat up past that point.
The problems may not show up like you think. It most likely will eat starters and burn out alternators rather than turning the key and having no power.
Diggindeeper
Diggindeeper
