battery question
+10
bigblockfox468
D's557BBF
KY JELLY
14 posters
battery question Empty battery question
Post  BOSS 429 August 23rd 2010, 11:03 pm
as most know the cars getting closer, but i havent had time to do any r and d on batterys
heres what i want most 12 or 16,but it must be the lightest good batt i can get,
what your batt weight? what brand do you run?
thanks rich
battery question Empty Re: battery question
Post  whatbumper August 23rd 2010, 11:14 pm
battery question A1110
42 lbs
1050 cranking amps. You only need one. They have free shipping. You can mount it any way you want too.
http://www.rockracingbattery.com/
Post  BOSS 429 August 23rd 2010, 11:17 pm
wow 42
Post  KY JELLY August 23rd 2010, 11:17 pm
x2 you will never go back to 12 if you buy one of these
KY JELLY
KY JELLY
Post  cool40 August 23rd 2010, 11:19 pm
can you just swap it into a 12v deal?
Post  whatbumper August 23rd 2010, 11:22 pm
cool40 wrote:can you just swap it into a 12v deal?
We did. the headlights are bright and the windows roll up really fast. lol
Post  cool40 August 23rd 2010, 11:26 pm
Laughing Laughing how's the radio sound?
Post  richter69 August 24th 2010, 12:11 am
whatbumper wrote:battery question A1110
42 lbs
Thats the battery the HeRo uses............. Wink
Post  cool40 August 24th 2010, 12:16 am
42 lbs
well ,by god,i'll have one too! Laughing
Post  bbf-falcon August 24th 2010, 6:57 am
Can you run a alternater w/these and how much does a charger cost Question
Post  D's557BBF August 24th 2010, 7:41 am
what about the lights on your gages?? I want to use a 16 volt system also.
Can you run a alternater?? come on hErO
D's557BBF
D's557BBF
Post  richter69 August 24th 2010, 8:10 am
You wont need an alternator, but you can run one.
I use the old Moroso charger which is said to have a "cleaner" charge, I think the guy that used to make them for Moroso now builds the one Rock sells.
Initial investment was 750 bucks and worth every penny.
Post  bruno August 24th 2010, 8:42 am
I run the xs powermaster 16v batt the s1000 weights 33 lbs ...they also off the new lithium tech nology if you are looking for some great weight savings
and if you get a hold of Joe Myabb he sells them http://www.joesraceparts.com/..he can work you a deal on a charger/batt combo ... and by the way there intelli charger works great for keeping the batt's conditioned
here is a pdf file of there batt
http://www.powermastermotorsports.com/xspowercat.pdf
http://WWW.CKRME.COM
Post  D's557BBF August 24th 2010, 8:48 am
does the 16 volt battery hurt the 12v gage lights??
D's557BBF
D's557BBF
Post  bruno August 24th 2010, 8:50 am
D's557BBF wrote:does the 16 volt battery hurt the 12v gage lights??
no
Post  bruno August 24th 2010, 8:51 am
no
the batt will rest lower then 16 volts ..... you do want to makes sure the power is disconnect before you charge .... at the 20 amp charge it will read 18 plus volts .... the msd stuff doesnt like that
Post  bigblockfox468 August 24th 2010, 8:55 am
So there is "no extra work" involved? .....like wiring issues, selonoids, ignition or whatever is electrically affected?
You just basically replace the 12v battery with a 16v battery and not have to worry or do anything else? scratch Suspect
bigblockfox468
bigblockfox468
Post  bruno August 24th 2010, 9:01 am
on a drag car no but yes .... on a street car with an ecu, fuel injection etc.... you do have to installer a voltage step down box --- http://www.summitracing.com/parts/PWM-993
Post  whatbumper August 24th 2010, 6:11 pm
We run the car, MSD digital 7, FAST XFI, intercooler pump and AMS-1000 all of the same battery with no step down box. If we ran an alternator then you would have to have one because the 18+ volts that you would get would kill the electronics. Our data logger shows exactly 16 volts at all times with the Rock battery. All we did was take the 12volt out and put the 16 volt in. We use the Moroso charger too but the one on Rock Battery's site looks like the same thing.
$599 for the combo with FREE shipping.
battery question A2210
or if you also want a 12v circuit.
battery question A3310
Post  Curt August 25th 2010, 7:17 pm
I have the V 16volt battery with dual post 16v & 12v. I have been happy with it, but customer service at Batteries r us is some of the poorest I have ever dealt with. The only thing I run on the 12v side is a LM1.
Post  David Cole August 25th 2010, 10:45 pm
Guess I'm in the minority. I've got other things I would rather spend 6-7 bills on.
For years I've run nothing but a single 12V battery and an alternator. Never a failure yet. Just a slow 2 amp charge the night before I load the car into the trailer, then race up to 2 days at a time without ever charging the battery. Never even take the charger out of the trailer, don't have to listen the generator, no step down box needed, no high voltage 16V alternator (that most put out around 19V) to fry electronics. It's never happened, but if my battery or charger crapped out I can go to the parts store 10 minutes away an be back with an exchange.
My dragster had a 588 at 14.5:1 on alky and never a problem with just a single Red Top Optima. ALWAYS started. Before that my other dragster and door cars had nothing but a big Wally World battery and alternator.
IMHO, if a single, fully charged 12V battery with an alternator won't start and maintain your stuff, you have a problem elsewhere.
Post  Curt August 25th 2010, 11:04 pm
Making things easier, isnt a problem. Most of use dont use a alternator, so 17.2 volts is about the highest voltage seen. Every product I own is very happy with the 16v except the LM1. All pro stock, pro mod, and allmost all top classes run 16v batteries. king
Post  Doug Rahn August 25th 2010, 11:14 pm
David Cole wrote:Guess I'm in the minority. I've got other things I would rather spend 6-7 bills on.
No, your not a minority David! I like my $95 Duralast Very Happy
Post  KY JELLY August 26th 2010, 9:01 am
One thing about it I have not talked to anyone that has switched to a 16 that said they would go back to a 12 and I am one of those people.
I will challenge anyone to completely drain a fuel injection system and start their engine faster than a 16 volt will with a 12 volt and an alternator. Very Happy No using them sissy primer deals either lol!
Go 2 weeks without charging and still have more power than a fully charged 12 volt .
KY JELLY
KY JELLY
Post  richter69 August 26th 2010, 9:06 am
KY JELLY wrote: One thing about it I have not talked to anyone that has switched to a 16 that said they would go back to a 12 and I am one of those people.
Ky is correct, I use my Primer Plus to heat it up fast.............no need as a starting aid as the Rock has that covered.
