wtb bunch of stuff
wtb bunch of stuff Empty wtb bunch of stuff
Post  nada 50 January 25th 2010, 9:55 pm
wtb
crank pulley prefer march
130 amp 1 wire alternator
alternator bracket to work with csr elect water pump
2-5/8 guages water temp, must have electrical sending unit, need pro comp ultr lite,
tach w/ light prefer pro comp ultra lite, but I'll see what you guys have
shifter for reverse c-6
thanks
updated 2/28
nada 50
nada 50
wtb bunch of stuff Empty Re: wtb bunch of stuff
Post  nada 50 January 26th 2010, 11:18 pm
nobody has anything
nada 50
nada 50
Post  Larry T January 26th 2010, 11:31 pm
i have a 100amp one wire altenator summit brand that is crome.i purchased it used but honestly it couldnt have been used for long it still looks like new i decided not to an altenator.i will take 100.00 and that includes the ride.i have paypal or if you would like to do it someother way let me know.send me a pm if interested.
Larry T
Larry T
Post  nada 50 January 27th 2010, 12:45 am
Larry T wrote:i have a 100amp one wire altenator summit brand that is crome.i purchased it used but honestly it couldnt have been used for long it still looks like new i decided not to an altenator.i will take 100.00 and that includes the ride.i have paypal or if you would like to do it someother way let me know.send me a pm if interested.
thanks, you have a pm
nada 50
nada 50
Post  bigblockfox468 February 15th 2010, 12:26 pm
Possibly help you on a shifter. I got a Hurst 1/4 stick, reverse shift, front exit cable. PM me a phone number if interested.
bigblockfox468
bigblockfox468
Post  nada 50 February 15th 2010, 1:14 pm
any pics, is that a full ratchetor is it where you need to pull the lever to down shift?
thanks
nada 50
nada 50
Post  bigblockfox468 February 15th 2010, 5:13 pm
nada 50 wrote:any pics, is that a full ratchetor is it where you need to pull the lever to down shift?
thanks
No pics yet. Shifter is still in the car. I sold my engine and trans. This shifter will not work with my new trans which will be a PG. I haven't taken the shifter out yet. I seen your wanted ad and thought I would let you know of the shifter I have and will be getting rid of soon.
To operate the shifter there is a front trigger lever kind of on the shifter which you must squeeze to pull the shifter back out of park. Once you are in 1st gear you pull shifter back to hit 2nd, to hit 3rd you must squeeze trigger lever and pull the shifter back. To down shift you must squeeze that trigger lever and push the shifter up to what gear you want. You can not go anything further then neutral because of a safety lock out to prevent accidental reverse and park shifts.
There is another seperate little lever on the left front that you must push forward to activate in order to get into reverse and then you do the same thing for park but you also have to squeeze that front trigger lever and push that little lever and the same time to get into park. It's kind of a 2 handed procedure to do the reverse and park thing. Fairly east to operate. Let me know and I'll get this shifter out and get some pics if needed.
bigblockfox468
bigblockfox468
Post  nada 50 February 15th 2010, 7:51 pm
ok thanks, I'll keep it in mind. Just looking for anything pretty cheap since I just got laid off this morning.
nada 50
nada 50
Post  Fast Fox February 15th 2010, 11:29 pm
I have a 100amp alternator, crank pulley, and belt that came off my bbf fox. Will sell separate or as a package deal let me know if interested!
Fast Fox
Fast Fox
Post  nada 50 February 16th 2010, 12:49 pm
is it the original pulley or aftermarket? How much do you want for it? I am also still trying to figure out if 100amp alternator will be big enough.
nada 50
nada 50
Post  Fast Fox February 16th 2010, 2:13 pm
Also, alternator is black and it put out over 14 volts and consistently held it while running at night even with lights burning! Pulley is not stock its aftermarket will have to look at part number this evening.
Fast Fox
Fast Fox
Post  Fast Fox February 16th 2010, 11:21 pm
Thought I had a number on the pulley but I dont it is ribbed not v-belt and so is the alternator, pulley is black and is in great shape just unsure of brand or partnumber.
Fast Fox
Fast Fox
Post  nada 50 February 17th 2010, 10:54 am
any pics? I was looking for the biggest alternator cause It's a street car w/ elect water and fuel pumps, elect fan, will have lights and more. I need to see what the amps all add up to.
nada 50
nada 50
Post  nada 50 February 17th 2010, 10:56 am
what brand is the alternator? do you have a bracket that will work with an elect water pump?
Thanks, Dave
nada 50
nada 50
Post  Fast Fox February 17th 2010, 8:38 pm
Sorry no pics right now earliest I can get some are this weekend as alternator is off but pulley still on car as I just recently decided to take off. Unsure of the alt brand but has a sticker on it thats says its a 100amp and its black two bolt holes and has the one wire hookup looks to be of very high quality and no bracket either mine was mounted a little differently.
Fast Fox
Fast Fox
Post  nada 50 February 20th 2010, 3:19 pm
ok, let me know when you can get them.
nada 50
nada 50
Post  Fast Fox February 24th 2010, 9:22 pm
Sorry it took so long but I finally got it off and some pics!
wtb bunch of stuff Ebay_r10
wtb bunch of stuff Ebay_r11
Fast Fox
Fast Fox
Post  Fast Fox February 24th 2010, 9:30 pm
Also, if you want them I will set em on your doorstep for $100 that includes alternator, pulley, bolts for pulley, and the belt I used in case it will work for you all you will need is alternator bracket and you will be in business!
Fast Fox
Fast Fox
