1999 Mercury Mystique window regulator help
61coon
747JetMech
1999 Mercury Mystique window regulator help Empty 1999 Mercury Mystique window regulator help
Post  747JetMech January 26th 2010, 5:05 pm
Has anyone replaced a window cable regulator. Looks like a pain in the azz.
747JetMech
747JetMech
1999 Mercury Mystique window regulator help Empty Re: 1999 Mercury Mystique window regulator help
Post  bbf-falcon January 26th 2010, 8:26 pm
All window regulators are apia
Post  richter69 January 26th 2010, 8:33 pm
bbf-falcon wrote:All window regulators are apia
yeah but these are even worse......we dont call them "mistakes" for no reason lol.
I'm no help man, I stay on the diesel side where I belong.
Post  61coon January 26th 2010, 8:37 pm
Go to a local salvage yard or two,try to the same make,model and color......Buy the door!!---RED
61coon
61coon
Post  95lightiningguy January 26th 2010, 8:48 pm
61coon wrote:Go to a local salvage yard or two,try to the same make,model and color......Buy the door!!---RED
lol! lol! lol! Easiest way! Exclamation
95lightiningguy
95lightiningguy
Post  Mike R January 26th 2010, 8:55 pm
They're not to bad, the hardest part is getting the window off. It's held on with an expandable nylon peg that has to be driven out through a hole in the vertical guide. After you replace the regulator replace the peg in the window, center it in the glass and drive the center pin back in, then install the glass and snap it into the regulator.
Post  bbf-falcon January 26th 2010, 8:55 pm
Exactly what I did a couple of weeks ago on my stepson's 98 Sunfire. Bought a complete door w/crankup window No
1999 Mercury Mystique window regulator help Empty Thanks
Post  747JetMech January 26th 2010, 9:11 pm
Is the peg a dealer item only?
I screwed with it about 6 months ago. I remember my hands were scraped up. Finally put a cheap vise grip on it. I am getting tired of reaching out the door for my Starbucks and burger fixes.
One more thing, this car has no trans filter. They want you to change trans fluid all the time to prevent failure.
Mercury Mistake!
747JetMech
747JetMech
Post  richter69 January 26th 2010, 10:03 pm
Hell the tranny is the best part on those cars.
They used to hold the recall record................that was until the 6.0 came along.
Post  69F100 January 26th 2010, 10:44 pm
Speaking of windows my Dad has a Ford Contour he was coming home from the Dr. and had stoped at K Mart to pick up a few things .They happen to get trash bags that day he was heading home he said he was just going to let the window down alittle bit and if fell to the bottom.Then it started raining on him so he pulls over to try to get the window up and couldn't so he get a trash bag out and puts over the window.Start heading home again to get about 2 miles down the road to be pulled over by a dupty sheriff said he pulled him over for the black trash bag over the door he couldn't see in the car.Daddy said he was OK with that until he starts telling he couldn't have the black bag over the window and he couldn't help that it was raining he would have to take it off .Daddy tried to tell him as soon as he got home he was going to put it under the shelter until he got it fixed that the window had just quit working about 15 or 20 min. ago and thats all he had in the car to keep the rain out he was only about 5 miles from home but the dupty told him if he didn't take it off he was going to give him a ticket so daddy pulled it off and he is 68 years old. The depty left going back to town daddy pulled back over and put it back on he said it took him 1 1/2 hours to leave K Mart to get home and should have only taken but about 30 min.
Post  richter69 January 26th 2010, 10:52 pm
Nothin' like a dick with a badge.................
Post  Mike R January 26th 2010, 11:37 pm
Yes the peg is dealer only but you should be able to reuse yours, I've never had to get a new one.
Post  res0rli9 January 26th 2010, 11:47 pm
Mike R wrote:They're not to bad, the hardest part is getting the window off. It's held on with an expandable nylon peg that has to be driven out through a hole in the vertical guide. After you replace the regulator replace the peg in the window, center it in the glass and drive the center pin back in, then install the glass and snap it into the regulator.
Hi, sorry to hi jack but I have to replace the regulator on 95 windstar. how do you get window off if it. Thanks Keith
Post  Mike R January 27th 2010, 9:22 pm
I don't remember for sure but it should be either bolted or it's riveted with 1/4 inch aluminum rivets. If it's riveted punch the center peg out and drill it out with a 1/4 inch drill bit. To replace them you need a BIG rivet gun to pull them but I've used 1/4 inch bolts with nylocs instead, just be careful not to over tighten them and break the glass.It's also possible that the regulator is riveted to the door shell also.
Post  69F100 January 27th 2010, 10:40 pm
My 98 Windstar windows has 1/4 rivets in it like was said knock the center pin out and drill with a 1/4 drill bit the nylon peace is 2 peace and snaps together so becarful when popping it apart and not chip the window like said use a 1/4'' bolt and nylon lock nut just snug it don't over tighten when you reinstall.
Post  res0rli9 January 27th 2010, 11:10 pm
69F100 wrote:My 98 Windstar windows has 1/4 rivets in it like was said knock the center pin out and drill with a 1/4 drill bit the nylon peace is 2 peace and snaps together so becarful when popping it apart and not chip the window like said use a 1/4'' bolt and nylon lock nut just snug it don't over tighten when you reinstall.
yes it has the two pease nylon but didnt remember the rivets, its my borthers and the motor guit and he bought the reg and motor already togather form auto zone and I couldnt fig how to get the window off so I told him to go back and just get the motor but the chinise motor dont line up right and had to longate the wholes a little to make it work right. but every few weeks it moves a bit and dont work right and I have to go back and fix it. so I told him to go buy the whole thing and ill try and find out how to get the window off. I wouldnt have this problem if he'd bought the ford motor but thay are big$$$$$.
Thanks guys, Keith
ps: somebody needs to steal Fords rivet guns Evil or Very Mad
1999 Mercury Mystique window regulator help Empty Well I Got It
Post  747JetMech January 27th 2010, 11:29 pm
Went to Pick N Pull today. Could not lower window manually with a cable system and no power. Tried getting the window up far enough to remove the 2 bolts that hold the regulator to the window............BASH!!!!! Window blew up in my face. My buddy just turned his head in time. After that is was easy. Unbolt 3 motor bolts, 4 regulator bolts, 2 bolts for the window attachment. Those nylon plugs are a little tricky but all in all, it wasn't too bad.
Heater motor runs full blast only ( Heater motor fuse unit ), window control pad shot, trunk lid supports shot.
Hoping to get 250k out of this. I have 175 already.
Thanks for the help
Tom
747JetMech
747JetMech
