DIVE 2 bolt main blocks/ Welding
We all have talked about putting 4 bolt main caps on 2 bolt main blocks. Its kind of costly to have it done.
On the 2 bolt blocks you see how the web radiuses down and out to the edge of the pan rail. Has anyone ever thought about taking the block to a competent welder and have him raise the rails with weld where the outer bolts from the caps would fasten? Then machine it.I know cast iron is a bitch to weld but they have some good rod and techniques out there for welding cast? Open for discussion and opinions.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: DIVE 2 bolt main blocks/ Welding
To Expensive and Stresses the Base Metal, Not the best Idea IMO, Cheaper to just get a DOVE Block..............
you still have a weaker,thin web block too.i'd buy a new block,motorsport,eliminator,before i spent much on a stock block for 4 bolt swap.wish i'd got one anyway.you can spend more than you think on a stock block if it's a real high hp deal and wish you'd got a new one for another 6-800 bucks more.depends alot on what your doen with it.
Tore wrote:It was just an idea.
If their wasn't a large supply of factory and a selection of aftermarket blocks it may have some merrit, but with the formentioned its probably not viable. In alot of cases if you take a look at the best long term solution its sometimes better to spend a little upfront and get a better Piece rather than attempting to modify a production piece when the are excelent alternitives avaliable. but to each his own, some like to play around, others like to get to the point.
Didn't Paul Kane have a thread on the other site where he made shims to go under the outer edges and the block? I think they machined the edges flat to accept the shims.
I never saw that but that was a thought. I believe IDT-572 ( Blake ) mentioned he did that. But this was just a question I was tossing out thats all.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Tore,Tore wrote:We all have talked about putting 4 bolt main caps on 2 bolt main blocks. Its kind of costly to have it done.
Thanks Tore
Blue Thunder and Programm main caps have a double-register that allows their caps to be fit to the standard webbing blocks which neck down next to the pan rail. That cast/unmachined area of the standard-webbed blocks is machined to accept the double-register cap's outter registers.
Or, if you want to install Milodon-style 4-bolt main caps (which are single-register caps intended for D0VE-A blocks), then you can do so using the method as shown HERE.
Paul
the only problem i had with that block was some cap walk,which is pritty normal for a 2 bolt when it spins high,but the biggest deal was the crack in the main webbing on #2 that went all the way to the cam.it was abused pritty bad for a long time and did'nt pop.i'm just thinken that a 4 bolt cap on a thin block is kinda like painting rust.
» cj block factory 4 bolt main can it handle more than other production blocks?
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» 2 DIVE blocks for sale
» D1 4 bolt main cap
» FORGED 557 ROTATING ASSEMBLY, TFS A460 HEADS, BILLET 4 BOLT MAIN CAPS, ARP MAIN STUDS
