Engine is done!!! 514 stroker UPDATED!!!!
+10
D. Sea
521fox4eye
racerk_2000
67460
scottke
bigjohn2007
jetsbaby
14 posters
Engine is done!!! 514 stroker UPDATED!!!! Empty Engine is done!!! 514 stroker UPDATED!!!!
Post  jetsbaby January 28th 2010, 5:27 pm
I posted this also on 460ford.com I thought you guys over here would enjoy looking at my build...I am very proud of my self of this engine build..
514 stroker
Block
460 Ford D1VE-A2B Block
Mag checked
Sonic checked
Bored to 4.440
Line honed
Decked to 10.310
Internal oiling system modified recommend by Paul Kane
Internals
Scat forged stroker crank 4.150
RPM Machine 6.8 inch rods
King Bearings
Comp Cams hydraulic roller cam speced by Keith Craft Racing
Mellimg Oil Pump modified by Paul Kane
ARP Oil pump shaft
Canton NEW “Cobra kit car oil pan” 8 qt with filter
KN oil filter with Filter Mag attached
Diamond pistons with for a total compression ratio of 10.25 to 1
Professional Products damper
Edelbrock water pump
Superformance burp tank
All ARP bolts used in build
Cometic head gasket MLS
Edelbrock Torker 2 port matched to gaskets
Mallory distributor
Tilton Super Starter
Taylor Spark plug wires 10mm
Jomar Valve train girdle
Canton main girdle
Heads
Edelbrock Performer RPM ported and polished on the Mad Porters advice
Transmission TKO 600 .82 over drive with mid shift installed and faded by me
McLeod RST twin disc clutch
Fortes Hydraulic slave set up on a Quick Time bell housing.
Concept One pulley system
Engine is done!!! 514 stroker UPDATED!!!! DSC03117
Engine is done!!! 514 stroker UPDATED!!!! DSC03118
Engine is done!!! 514 stroker UPDATED!!!! DSC03119
Engine is done!!! 514 stroker UPDATED!!!! DSC03120
jetsbaby
Engine is done!!! 514 stroker UPDATED!!!! Empty Re: Engine is done!!! 514 stroker UPDATED!!!!
Post  dfree383 January 28th 2010, 7:54 pm
Looks nice.
Post  bigjohn2007 January 28th 2010, 8:46 pm
looks great Very Happy
bigjohn2007
bigjohn2007
Post  bruno January 28th 2010, 10:40 pm
love the detail on the build
http://WWW.CKRME.COM
Post  scottke January 28th 2010, 11:32 pm
Looks Gooood!
scottke
scottke
Post  Curt January 29th 2010, 12:23 am
I like where you put the muffler. Wink
Post  67460 January 29th 2010, 1:30 am
Good looking Engine, you should be proud.
67460
67460
Post  racerk_2000 January 29th 2010, 12:48 pm
Looks sharp.
Where did you get the valve covers?
racerk_2000
Post  521fox4eye January 29th 2010, 1:05 pm
looks great..congrads!! nothing like sum good ol american iron.if you don't like how the torker intake works out let me know,ill make u a great deal on a vic jr
521fox4eye
Post  D. Sea January 29th 2010, 1:10 pm
Nice build, congrats!
D. Sea
D. Sea
Post  jetsbaby January 29th 2010, 3:16 pm
racerk_2000 wrote:Looks sharp.
Blue Thunder Comps painted Hi temp VHT wrinkle finish
jetsbaby
Post  IcallhimGeorge January 29th 2010, 3:24 pm
and this engine is going in a kit cobra? Hang on!
IcallhimGeorge
IcallhimGeorge
Post  hillbillyerv January 30th 2010, 7:02 pm
Wow that does look super clean Twisted Evil
hillbillyerv
hillbillyerv
Post  uf63 February 1st 2010, 12:19 am
Where did you get your valve covers? Very nice cheers
uf63
uf63
Post  jetsbaby February 3rd 2010, 2:12 am
uf63 wrote:Where did you get your valve covers? Very nice cheers
jetsbaby
Post  jetsbaby February 18th 2010, 12:50 am
Video of engine running
Engine is done!!! 514 stroker UPDATED!!!! Th_20100213164450
jetsbaby
Post  56Tbird February 18th 2010, 8:38 am
That's an awsome build !! That'll be one bad car when finished!!Super cool Twisted Evil king
56Tbird
56Tbird
