dooe-r timming
dooe-r timming Empty dooe-r timming
Post  mach1charlie January 29th 2010, 10:03 pm
Working on a 557 with dooe-r heads in a rear engine dragster (bracket car). On race gas @ 14.5 compression, what is best total timming for the old school, cast iron heads?
I have seen dyno sheets @ 44 That I find hard to believe, bsfc was over 1.
Can anyone give me any insight ?
TIA Charlie
mach1charlie
dooe-r timming Empty Re: dooe-r timming
Post  Lem Evans January 29th 2010, 10:08 pm
Start at 32*...move 1-2*up or down untill the e.t. slip says ...no.
Post  mach1charlie January 29th 2010, 10:19 pm
Thanks Lem, thats what I expetced, all my chevy buddies looked at me like I was nuts !
Charlie
mach1charlie
Post  Lem Evans January 29th 2010, 10:23 pm
Tell the chevy guys to kiss my ass Exclamation
Post  Bret Powell January 30th 2010, 12:27 am
With a good intake, a lot of cam and dome for compression in a small motor w/big bore. 35 has usually been the max. Generally around 33* is the sweet spot, maybe up 1.
Tell the Chevy guys you don't need 50cc of mountain for the flame to climb over!
Bret
Bret Powell
Post  dfree383 January 30th 2010, 9:26 am
Bret Powell wrote:With a good intake, a lot of cam and dome for compression in a small motor w/big bore. 35 has usually been the max. Generally around 33* is the sweet spot, maybe up 1.
Bret
or have a 120cc's of valley for the valves and spark plug to hide in......... Laughing
Post  DaveMcLain January 30th 2010, 12:06 pm
I can't see 44 degrees being right for any engine unless the pointer is not correct(most likely). I can't believe that 33 degrees would be far from optimum one way or the other.
DaveMcLain
