locked timing on street/strip
gas6999
butterbean
gmsmkr
Would you guys run the timing locked out on a street/strip car?
Pros/cons
Pros/cons
gmsmkr- Posts : 1364
Re: locked timing on street/strip
if you are talking street cars like ours yes, mine is and my past "street" cars were too!!!!!!!
butterbean- Posts : 676
Cars like ours.....Dat be what I'm talkn bout
![jocolor](https://2img.net/i/fa/i/smiles/icon_jokercolor.png)
timming
you can run a timing locked but you will need to have a timing retard for starting, I know a lot of guys that do but you will notice it on the bottom end,.
gas6999- Posts : 20
gmsmkr wrote:Would you guys run the timing locked out on a street/strip car?
Pros/cons
street car. I wouldn't. only case that should be done imo. is when the RPM id Always above 3K in traffic in low gear ang low mph.
DanH- Posts : 1081
Mine is. Spin motor over, flip switch, fires right up.
BigBlockRanger- Posts : 1260
gas6999 wrote:you can run a timing locked but you will need to have a timing retard for starting, I know a lot of guys that do but you will notice it on the bottom end,.
We don't run a lot of timing on BBFs. I wouldn't run a start retard.
Curt- Posts : 2790
same as mine spin it over then flip the switch no problem and its only at 32* total
I have always locked the timing out on all my race and street cars, just let it roll before hitting the ignition to start you will be fine...
the Coug- Posts : 3055
Curt wrote:gas6999 wrote:you can run a timing locked but you will need to have a timing retard for starting, I know a lot of guys that do but you will notice it on the bottom end,.
mine wanted 36* and my ole cars wanted 38* it all depends what your car wants, all this 30 or less is not always right, every engine wants what it wants. Not everyone lives at 1000 feet or less sometimes when I race and the corrected elevation is 5000 to 9000 feet
the Coug wrote:Curt wrote:gas6999 wrote:you can run a timing locked but you will need to have a timing retard for starting, I know a lot of guys that do but you will notice it on the bottom end,.
He lives in Alabama. He wont see much altitude.
Curt- Posts : 2790
» Timing locked out??
» Locked Timing
» Locked Timing ??'s
» Roots blower intercoolers
» Moroso street/strip oil pan questions
» Locked Timing
