fe solid roller lifters in a 460
can i use solid roller lifters for an fe(428) in a 460?
new2460- Posts : 195
Re: fe solid roller lifters in a 460
It seems to me that I've read somewhere that even thought the FE roller lifters will fit in a 429 / 460 block, the lifter bore spacing is different. This causes a bind in the alignment bars on the lifters @ full lift resulting in $$$$$ breakage. Someone else who has more / better info will surely chime in. I hope I was helpful.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
The lifters will PHYSICALLY interchange however, the FE lifters hane NO oil going through them as the FE valve train is oiled through the rocker shafts; NOT the pushrods.
Some FE's use the 385 lifters as that is not a problem.
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» hydraulic roller cam with solid roller lifters
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» Hyd Roller Cam with Solid Lifters
