Custom ground camshaft kits through RHP
Any flat tappet hydraulic cam and lifter kit custom ground for your specific application $222.00.
the solid flat tappet cam and lifter kits are $234.00
Solid roller camshafts $325.00.
Consultation will be necessary to design a cam for your combo based on parts choices, intended use, vehicle type etc...
We have a very wide variety of comp, crane and lunati lobes available.
All cams are ground on brand new CWC cores.
Lifters are notched for additional lobe / lifter crown interface oiling.
The full lunati voodoo hydraulic line is now available...
All listed prices are plus shipping.
All cams come with assembly paste containing moly disulfide AND ZDDP. This is the heavy stuff that sticks to the lobes and does not run off...
Re: Custom ground camshaft kits through RHP
When I get my heads I WILL be giving you a call!!!!
Jeremiah- Posts : 157
Jeremiah wrote:When I get my heads I WILL be giving you a call!!!!
Thank you good sir...
I know this is kinda off topic from the forum but do you do smallblock grinds?
Maddmattmustangs wrote:I know this is kinda off topic from the forum but do you do smallblock grinds?
Scotty can do any grind you want small block or big Block
the Coug- Posts : 3055
the Coug wrote:Maddmattmustangs wrote:I know this is kinda off topic from the forum but do you do smallblock grinds?
The short answere is yes. Small block, cleveland, FE and Lima.
The lobe catalog contains most of the comp lobes, the lunati voodoo line, crane grinds etc. There are a very large number of lobe designs for me to choose from when custom speccing a cam. I have on occasion utilised a comp intake and another companies exhaust lobes. Just depends on what the combo needs to accomplish.
Sounds good. What number do I call and when is best? Also do you have experience working over holley strip dominators? Might need that done as well..
The number in the signature is fine.
10 to 7 mon thru saturday PST.
» RHP Custom Ground SFT cam and lifter set - NIB
» custom grind camshaft
» FS: 1967 Ford Custom 2 door sedan with '67 Ford Custom parts car (Galaxie body)
» relay for tb
» Tornado on the ground !!!!!
» relay for tb
