Flex Plate? "running true"
I inspected my brand new Scat Flex plate and noticed that if I lay the plate down on a flat surface it has a very small amout of "rock" to it in one direction. (very small amount) Is this anything to worry about?
jones- Posts : 2230
Re: Flex Plate? "running true"
how flat is your flat surface?
Work bench. I turned the plate around to nake sure it wasn't the surface and the rock stayed in the same place.
jones- Posts : 2230
Scat SFI flexplates suck. End of story.
To put it into perspective, I had nothing but trouble with my Scar unit. Out of round, runout, you name it. Yanked that piece of crap out and put in a parts store flexplate and have had absolutely zero problems since.
Greg
Greg
Greg_P- Posts : 1009
I can't remember if mine is a Scat or Cat but it had some run out and i had to use a shim with the starter.If not it would make a little noise when turning over i bought the shim at Napa,Later Mark.
Mark Miller- Posts : 1959
» New CSR Flexplate
» CSR flex plate ???s
» CSR FLEX PLATE
» Flex plate ? going from a c6 to a PG
» bbf jw wheel flexplate $175
» CSR FLEX PLATE
