Fuel consumption
Fuel consumption Empty Fuel consumption
Post  '65 T-BOLT February 13th 2010, 6:52 pm
I have a 93 F350 crewcab 4x4, 460 gas..110,000 miles, auto, 4:10 gears and 33' tires. I am getting 8 mpg running easy down the highway. What should something like this get normally? or is this just about right? What can be done to help this get better gas milage? I have an 86 1 ton dodge, 360..headers,4 bbl carb,small cam. stick,4:10 gears,38" tires. It gets me 16 on the highway. Thanks all in advance!
'65 T-BOLT
'65 T-BOLT
Fuel consumption Empty Re: Fuel consumption
Post  BOSS 429 February 14th 2010, 11:31 am
FORD DID A STUDY IN THE 90S, a lot matters, sun visors,running boards,bug sheilds, etc
but as you asked most get 10 to 12 mpg (460 efi)
some get better,
Post  bb429power February 15th 2010, 8:01 pm
If you put headers on it, a lockup converter or manual trans, low rpm range cam, new intake and carb, it will get better performance and not have to work as hard to keep going. Also, the tires play a role (not that much though).
bb429power
bb429power
Post  whatbumper February 16th 2010, 11:18 am
'65 T-BOLT wrote:I have a 93 F350 crewcab 4x4, 460 gas..110,000 miles, auto, 4:10 gears and 33' tires. I am getting 8 mpg running easy down the highway. What should something like this get normally? or is this just about right? What can be done to help this get better gas milage? I have an 86 1 ton dodge, 360..headers,4 bbl carb,small cam. stick,4:10 gears,38" tires. It gets me 16 on the highway. Thanks all in advance!
I would have to agree with the lockup convertor and possibly a different trans out of a newer ride. With a different trans with a lower first you could change the gears to 3.73's and still pull the same.
Post  TorinoGT February 16th 2010, 12:15 pm
I have a 1995 F350 4x4 standard cab 8 foot bed... on 33's, 460/C6 and 4.10's it gets less than 10 miles per gallon... mine actually seems worse at extended highway speed due to no overdrive. aside from the 33 inch tires, I have NO exterior mods (no visors, bug shields, running boards, lights etc) Its always been a thirsty rig...
Shane
note: my truck only has 88,xxx miles on it. I bought it new in feb 1995... so its not a tired old truck either!
TorinoGT
TorinoGT
Post  '65 T-BOLT February 16th 2010, 4:47 pm
Hey guy's! thanks for the replies. My truck does have the automatic overdrive trans in it, visor,running lights on roof and fender flares. I was thinking that this thing should get at least 12/14 mpg, not 8!
whatbumper: beings this truck is also gutless in power, I think it needs to keep the 4:10 rears.
'65 T-BOLT
'65 T-BOLT
