Elec. Waterpump
ebustin
BIGDOG466
Elec. Waterpump
I'm looking for a Meziere or CSR elec waterpump with back plate in good condition.
BIGDOG466- Posts : 265
Re: Elec. Waterpump
I think I still have a Meziere (Blue) 460 pump used for two dyno runs. No back plate.
ebustin- Posts : 12
Re: Elec. Waterpump
How old is it? How much? Is it a 55 unit or the smaller one?
got one
I have a 55gpm meziere for plate setup, 2 of them ..... 1-440-714-9399 ..... Thought the pump wasn't working, wrong! Between meziere tech and Griffin tech it's been determined the rad. is under sized..... i need a new Griffin rad 31x19 2row 1.25 that cost $289 and i'm sitting here with over a grand in meziere pumps! You can have either one... we can figure something out......
Rick
Rick
4pasnu- Posts : 3
Re: Elec. Waterpump
4pasnu wrote:I have a 55gpm meziere for plate setup, 2 of them ..... 1-440-714-9399 ..... Thought the pump wasn't working, wrong! Between meziere tech and Griffin tech it's been determined the rad. is under sized..... i need a new Griffin rad 31x19 2row 1.25 that cost $289 and i'm sitting here with over a grand in meziere pumps! You can have either one... we can figure something out......
Rick
What you want for one? You got the plate also?
Re: Elec. Waterpump
99 bucks on ebay you can get the procomp one ....i have one, i know dan the sticker guy has one....i know i will get shit for saying this, but considering the true life of any electrci pump why do u neeed to spend over 300 for a name.....all i have to do as check the gasket on it and add a little rtv and you are good.....mine has working great even in the 100 degree heat with no problems,, never gets over 180
hey
Hey frank how much hp are you pushing? Were around 700 on motor.....I can't keep this thing cool, tech @ griffin says the rad is to small? What rad are you running?
I have no plate.... $250.00
4pasnu- Posts : 3
Re: Elec. Waterpump
Do you have a resticter in the thermostat if not try a 5/8 hole one, may be circulating too fast not enough time to cool in rad.
Re: Elec. Waterpump
Just did that, waiting for the 40*below to come in the mail.... Trying to figure out were to come up with the cash for a new rad....It'll be fine at the track when it can cool down.... Just like to be able to strap the car seat into it and take the grandson for icescream 2 miles down the road! lol
4pasnu- Posts : 3
Re: Elec. Waterpump
Is your carb lean? fatten it up. I am on E-85 and I can go in the burnout box at 150 and after the 1/8 mile pass be at 165. Best thing I did was install a shroud around the E-fan that helped the most
Re: Elec. Waterpump
Rick
4pasnu... you have a PM
138- Posts : 1593
Elect waterpump
Griffin makes a double core rad with 1.5" cores but it is more than $300. It help with my over heating along with removing the bypass hose, adding three .375" holes in the stat for cold starting and remove underspeed water pump pulley.
Mike
Mike
nottoold545- Posts : 28
» CSR elec. waterpump/ 460
» ELEC SHIFTER
» Need assistance on elec. choke
» 460 Water Pump
» Elec water pump and valve cover 460 BBF
» ELEC SHIFTER
» 460 Water Pump
