xbeaing's
+9
342g
Frank Kramer
jesse
13 posters
xbeaing's Empty xbeaing's
Post  jesse February 21st 2010, 12:51 am
i have .0026 now on the mains
if i use a half set of xbearings what would that put me at?
jesse
jesse
xbeaing's Empty Re: xbeaing's
Post  bbf-falcon February 21st 2010, 1:16 am
Should put you just over .003. Perfect imo Smile
Post  jesse February 21st 2010, 1:37 am
thats what i was thinking
thanxs
jesse
jesse
Post  Frank Kramer February 21st 2010, 6:27 am
Tell us a little bit more on your engine.
Its been a couple of years ago but I think we were running about 0.0036 to 0.0040 on the mains with a TITAN oilpump in our nat asp engines.
Maybe you will need more clearance.
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  jesse February 21st 2010, 11:45 am
svo block
tfsA heads
4.500 scatt forged
6.8 olivers
diamond customs
kasse oil pump
wet sump set up
last few seasons i was running 4.300 stroke with a 4.440 bore
i had a oil ine failure last year and messed up rods and crank
so i changed my bore/stroke to help out the heads
but i ran it 7200 rpm's most of the time
but it did hit 8000 on real losse tracks
i dont like to run higher r's but sometimes it is needed to get the job done
so i want to build this right so i feel confident it will hold up
jesse
jesse
Post  bbf-falcon February 21st 2010, 6:29 pm
Jesse, First I would mock it up w/both top and bottom x's and see what u got. .0035 would probably be fine on high rpm deal like yours. JMO
Post  jesse February 21st 2010, 9:03 pm
that is what i am gonna do just to be safe
i would rather be a bit over .003 than under
jesse
jesse
Post  Lem Evans February 21st 2010, 9:33 pm
A bit over .003" is normal.... ..0035" is safe .
Post  jesse February 21st 2010, 10:04 pm
after i got off the phone with lem last night i decided to plastic gauge
yea i know not a good way but i didnt have the right tools here last night to
do it right
but it came to under .002
so like lem told me to do i am gonna take the crank out and
see were i am at with half x's and full set
jesse
jesse
Post  138 February 21st 2010, 10:23 pm
jesse wrote:after i got off the phone with lem last night i decided to plastic gauge
do it right
just out of curiosity..what tools would be required? mics, and dial bore gauge? to do it right...
138
Post  jesse February 22nd 2010, 6:09 pm
mic and a dail bore gauge is what i like to do
but i dont have eather
but i am borrowing them to check it out
this evening
jesse
jesse
Post  rmcomprandy February 22nd 2010, 7:34 pm
JEEZ ... you guy's like some WIDE clearances.
Clearance is your friend with marginal parts which flex but, I don't go anywhere near that big when good, strong parts are used.
I guess everyone has their pet sizes...
Post  138 February 22nd 2010, 7:39 pm
well what do you suggest then with forged components...race application? what oil weight?
138
Post  the Coug February 22nd 2010, 8:13 pm
Randy maybe he is using 90 weight oil.... lots of these guy's think you have to run oil so thick it has to be heated to drip or run. well all I see it does it just create bearing drag and cost hp not to mention be hard on oil pump shafts in the distributors......a good 10-30 synthetic is great and WAY LESS DRAG ON PARTS
Post  Lem Evans February 22nd 2010, 8:44 pm
I do what works .
Post  bbf-falcon February 22nd 2010, 8:51 pm
imo, I would rather have a little over normal in a race engine than not enough.
Post  342g February 22nd 2010, 9:01 pm
So what clearance for 20-50 Brad-Penn oil?
342g
342g
Post  Lem Evans February 22nd 2010, 9:20 pm
5,000 or 9,000 rpm ? Dry sump or wet sump and with what pump and pan ?
No one answer .
Post  138 February 22nd 2010, 9:33 pm
7000, wet sump, kasse, not sure what pan... anyway just dragin the waters for knowledge at this point...
138
Post  bbf-falcon February 22nd 2010, 9:40 pm
342g wrote:So what clearance for 20-50 Brad-Penn oil?
Harold, IMO with that wt oil I would'nt want anything less than .003 on the mains . even a little more would make me feel more at ease.
Post  342g February 22nd 2010, 11:11 pm
Some seem a little edgy. Surprised
342g
342g
Post  bbf-falcon February 22nd 2010, 11:43 pm
Harold,
Do they make that oil in 10w30 or straight #30 Question
Post  342g February 22nd 2010, 11:45 pm
Harold,
I'll let you know tomorrow, stay tuned. Very Happy
342g
342g
Post  jesse February 23rd 2010, 12:11 am
go the xbearings today
my machinest had the set on hand
not shure why but worked good for me
he came over tonight and brought his stuff over
we checked it with half xbearings and half standerd
turn's out i am at 3.5thou
and we also checked it with standerd bearings
and comes out to about 3.1 thou
we are not shure how he came up with 2.6 when it was at his shop
but we checked it a number of times tonight keep comming up with 3.1-3.5
but when i checked it with plastic gauge like i said
i got barly 2 thou
so could plastic gauge be off that much?
now i just gotta figure out if i wanna run 3.1 or 3.5
jesse
jesse
Post  138 February 23rd 2010, 1:06 am
the options never stop... bounce
138
