Question on C9VE-A Heads
+8
138
longroofracer
TS6034
12 posters
I just found a 69 Lincoln Continental Mark III. The car is almost rust free. The interior is in great shape too. I looked at the casting numbers on the heads and they are C9VE-A. The engine looks to be original and the id tag under the hood says 365HP. Are these heads good?
The car runs good. The guy drove it an hour one way to show it too me. I'm interested in the car because of the engine. A while ago I bought a 77 460 that ended up needing a rebuild. Now I'm thinking about buying this Lincoln for the engine and maybe putting the 77 460 back into the Lincoln.
I can get the car for a thousand dollars. Just wanted to know if it's worth it.
TS6034- Posts : 12
Re: Question on C9VE-A Heads
That is a pretty hard to find car these days just to harvest an engine... imo, and swapping them back and forth is a lot of work to gain a little compression and hp. Depending on when it was actually built... it could possibly have a D0VE A block, if really need for your application? If you are planning to rebuild the engine anyways, you might be money ahead to use what you already have and the $1000 bucks to get started.
longroofracer- Posts : 250
My god that car is downright georgous and awfully well-kept for being 40 years old. Please, please don't take it apart! That is the cleanest example of a 1969 Lincoln I have seen in years.
If you want C9VE heads and block, I got 'em. Further, you can easily get a running 1969 engine for less than $1000 and you won't have to do the engine swap. Yes, the heads are identical to D0VE heads (I actually have a preference for C9VE heads over the D0VEs in some cases) and the block is your typical standard-webbed 2-bolt block (also one that I like).
I don't know where you're located but based on the snow I imagine it's far away from me....I sure wish that Lincoln were closer to me as I'd jump on it today and keep it just as it is...
Paul
Paul
Yes, yes, yes, better to use the $1000 to rebuild your current engine.longroofracer wrote: If you are planning to rebuild the engine anyways, you might be money ahead to use what you already have and the $1000 bucks to get started.
Now, where's the car?
Paul Kane wrote:My god that car is downright georgous and awfully well-kept for being 40 years old. Please, please don't take it apart! That is the cleanest example of a 1969 Lincoln I have seen in years.
Paul
I think you should buy it and bring it to the Rocky Mountain Throwdown this year.
by the car and trade it to Paul for a grand worth of at cost parts.... that car belongs to someone who will return it to its original state
138- Posts : 1593
Man with a car that big you can get 142 Illegal aliens in it and 36 in the trunk alone
Man don't seperate that car some Pimp around will kill for it..... 15 inch wide spoke wheels and 3 inch wide tires mounted on it and some Hair chocks they will be stylin and profilin......
the Coug- Posts : 3055
just where is that car anyway???..........I had one of them in 69. wish I still had it
res0rli9- BBF CONTRIBUTOR
I'm also a big fan of that nunbe.,ahahah I mean year . Please don't seperate that car and engine.
I will probably buy it regardless. I think it'd be cool to drive it during the summer.
TS6034- Posts : 12
Paul Kane wrote: you can easily get a running 1969 engine for less than $1000 and you won't have to do the engine swap.
Paul
No, I can't easily find a running pre-smog 460. I look everyday and have been looking since late summer. There's nothing around where I live. I search within two hundred mile radius too. Nothing.
TS6034- Posts : 12
buy it and put 521 crank rods and pistons in it and set it on cruse
TS6034 wrote:Paul Kane wrote: you can easily get a running 1969 engine for less than $1000 and you won't have to do the engine swap.
Paul
So, where are you located? If we knew, maybe someone could help you find one.
Nevs- BBF CONTRIBUTOR
TS6034...where do you live?
'65 T-BOLT- Posts : 1464
TS6034 wrote:I live in Michigan..
Well, that narrows it down...
Hell I.ve got a block and heads evrything you need for a motor I'll buy the car let me know where
dave d- Posts : 809
Nevs! at least we have a state! one step at a time!, if he were closer i have a 69 Lincoln 365 hp engine, complete!
'65 T-BOLT wrote:Nevs! at least we have a state! one step at a time!, if he were closer i have a 69 Lincoln 365 hp engine, complete!
Baby steps...
Well craigslist is a bitch. I can see the ad now... "to the guy from ##### Michigan with the 69 Lincoln" haha.
At this point, I'd drive about anywhere in the state for a decent set of heads or even a complete engine! Sooo.....if somebody has something near Mi, let me know?
TS6034- Posts : 12
GOT WHAT YOU need and only 90minutes south of OHIO-michigan line
dave d- Posts : 809
are you in the UP?
Diggindeeper- Posts : 800
dave d wrote:GOT WHAT YOU need and only 90minutes south of OHIO-michigan line
Ok, tell me about it. retnasmot@yahoo.com
TS6034- Posts : 12
Diggindeeper wrote:are you in the UP?
No, but I'm close. You?
TS6034- Posts : 12
TS6034 wrote:I just found a 69 Lincoln Continental Mark III. The car is almost rust free. The interior is in great shape too. I looked at the casting numbers on the heads and they are C9VE-A. The engine looks to be original and the id tag under the hood says 365HP. Are these heads good?
The heads are good some of the better factory heads DOOR's are better but rather rare.
» how fast did you go with DOVE,C9VE,OR C9VE HEADS?
» Putting guide plates on my C9VE 429 heads.
» Porting C9VE heads got 224 cfm at .800 lift... good?
» ??? c9ve-a heads rocker arms
» Rebuilding a set of C9ve heads. Advice please
