what will this combo make ?
badnotch
what will this combo make ? Empty what will this combo make ?
Post  badnotch February 23rd 2010, 4:24 pm
514
12.5 compression
fms-scj aluminum - unported
solid roller 268-276
726-726
108 center
4.390 bore
4.3 stroke
badnotch
badnotch
http://www.gnlmotorsports.com
what will this combo make ? Empty Re: what will this combo make ?
Post  bruno February 23rd 2010, 4:35 pm
With a victor and a big Domi i would say around 700-750hp
http://WWW.CKRME.COM
Post  badnotch February 23rd 2010, 4:39 pm
with unported heads damn
badnotch
badnotch
Post  IDT-572 February 23rd 2010, 4:57 pm
Brandon's 501 I built with ported scj's and basically the same cam made 740 hp and 660 tq.
Post  badnotch February 23rd 2010, 5:13 pm
what would you build scj,s or street heats ?
badnotch
badnotch
Post  richter69 February 23rd 2010, 5:17 pm
out of the box the streets, if you gonna port then the SCJ, if you can find a deal on a set then which ever ones you find.
Post  dfree383 February 23rd 2010, 5:17 pm
Unported go with the SCJ's IMO
Post  IDT-572 February 23rd 2010, 5:23 pm
Max ported theirs not a bunch of difference between the two in my book. It seems the streets will make a bit more torque and the SCJ's will make a bit more hp.
If I were starting new and wanted a good running conventional headed deal, I would get the P-51's .
I have seen three different 557 flat top solid roller engines make 900 hp. At 6900 rpm, with out of the box heads with a cartridge roll clean up in the bowls.
You can almost be drunk and make 850 with them.
If your talking un ported and buget deal, go with the SCJ's Lem sales. And you can step to the P-51's later with no other changes.
Post  badnotch February 23rd 2010, 6:26 pm
what do the p-51 s cost and what intake goes with them ?
badnotch
badnotch
Post  dfree383 February 23rd 2010, 6:33 pm
Last I saw they are in the mid $2k ish range complete depending on how you get then set-up, they take the same intake as regular scj / CJ Stuff
Post  IDT-572 February 23rd 2010, 6:51 pm
They have the same valve placement as the SCJ's but have their own chamber shape and dome configuration if going with a dome piston.
Post  '65 T-BOLT February 23rd 2010, 7:01 pm
This is my build, but with 521" Ported aluminum SCJ's,same cam and a tick less compression. so I will be happy with those numbers
'65 T-BOLT
'65 T-BOLT
Post  badnotch February 23rd 2010, 9:03 pm
well thought i had the c-heads sold , guy just backed out -so ill be waiting until they are gone Sad Sad
badnotch
badnotch
Post  '65 T-BOLT February 23rd 2010, 10:26 pm
sorry to hear he backed out
'65 T-BOLT
'65 T-BOLT
Post  Mark Miller February 24th 2010, 1:54 am
Gerry,
Good luck on your new build FYI a 4.39 bore and 4.3 stroke is 520.68 ci.That seems like a good combination something i would like to build down the road.
Later Mark.
