Cylinder Temperatures measured at header
purple venom
Cylinder Temperatures measured at header Empty Cylinder Temperatures measured at header
Post  purple venom February 26th 2010, 12:34 am
Purchased an infrared temp gauge and thought I would try it out on measuring the temperatures on my header tubes. I would think they should all be within 30 degrees of each other, however, I measured #8 to be about 50 degrees cooler than any other. What do you think, just measured in the wrong spot or a potential problem? If a problem, what would cause a cylinder to be so much cooler?
purple venom
Cylinder Temperatures measured at header Empty Re: Cylinder Temperatures measured at header
Post  bruno February 26th 2010, 5:48 am
i would say at idle that it would be common to see that much of a diff
http://WWW.CKRME.COM
Post  rmcomprandy February 26th 2010, 10:34 am
Unless someone has already done some distribution work on it .... 50 degrees is CLOSE.
Cylinder Temperatures measured at header Empty temperatures
Post  hpwdboss1 February 26th 2010, 9:32 pm
Have checked my header tubes a few times the same way. At idle, a range of 75 or 80 degrees from front to rear was common with the cylinders closest to the primary side being coolest. Have been wanting to check head temps ,front to rear, a.s.ap. at the end of a pull.
Perry
hpwdboss1
hpwdboss1
Cylinder Temperatures measured at header Empty header temps
Post  blown473 February 27th 2010, 1:35 pm
I tried the same thing, did temp monitoring with engine combo changes, found them same results, the temps varied as much as 75 degrees .
blown473
blown473
Post  purple venom March 2nd 2010, 12:28 am
Thanks for the replies. I feel better now. So, what would cause it? How does one cylinder run richer or leaner than the others?
purple venom
Post  DILLIGASDAVE March 2nd 2010, 1:08 am
Is the temp difference more a function of the intake shape/design, or header shape/design? Or a little of both?
Post  dfree383 March 3rd 2010, 12:49 pm
Fuel Distribution Causing Leaner / Richer Cylinders
