Welding on aluminum heads?
+8
jesse
chuck stevens
86 coupe
Maddmattmustangs
12 posters
Welding on aluminum heads? Empty Welding on aluminum heads?
Post  Maddmattmustangs March 5th 2010, 3:20 pm
Is it possible to weld inside combustion chambers of aluminum heads and have it actually stay there and not run out under combustion temps? Kinda got into a discussion about that and my entire shop class thinks its not possible Mad
looking for second opinions
Maddmattmustangs
Maddmattmustangs
Welding on aluminum heads? Empty Re: Welding on aluminum heads?
Post  86 coupe March 5th 2010, 3:43 pm
yes it's a common fix. there are no problems if you are a good welder
86 coupe
Post  138 March 5th 2010, 3:45 pm
if it is welded correctly it will stay put... will it actually fix the problem?... that depends
138
Post  IDT-572 March 5th 2010, 4:16 pm
There is not much you can't fix on an aluminum head. Welding a chamber is not a problem.............
Post  69F100 March 5th 2010, 10:40 pm
if you get the head hot enough for the aluminum weld to run out you will have a bigger problem than the weld running out But like what was said if you prepair the head right the weld will be as strong as the head if not stronger
Post  Nevs March 5th 2010, 10:47 pm
Maddmattmustangs wrote:Is it possible to weld inside combustion chambers of aluminum heads and have it actually stay there and not run out under combustion temps? Kinda got into a discussion about that and my entire shop class thinks its not possible Mad
I hope your shop instructor doesn't hold that same opinion, if he does, I'd switch classes! Laughing Laughing
Post  chuck stevens March 5th 2010, 11:06 pm
X2+.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  jesse March 6th 2010, 12:15 am
x3
i weld alum for a living
the head is a cast alum unlike steel is not an issue
but on a cast alum pice the weld it self will be stronger than the
cast it was welded on
welding chambers is common
and if done right will not hurt the head
i belive kasse welded the chambers on a emc motor he done
jesse
jesse
Post  richter69 March 6th 2010, 12:24 am
as others have said it will be fine if done right.............
Welding on aluminum heads? Empty Re: welding aluminum heads
Post  hpwdboss1 March 6th 2010, 12:37 am
Am looking at a set of heads on my shelf that were bad hurt in a dropped valve deal. Indy Cylinder Head put in seats, guides and a bit of weld to fix my mistake. Yeah, you can weld them and they will live!
hpwdboss1
hpwdboss1
Post  Maddmattmustangs March 7th 2010, 12:37 am
shop instructor and i talked after class about it and he said it can be done and he pointed out a procomp head i could use to prove them wrong with.... god that thing looked like crap i dont know if that aluminum can even be worked with. Be fun buz cutting it in half though.
I was talking about welding chambers on a head like a scj to shrink chamber size and completely unshroud the valves for better flow and efficiency. does that make since?
Maddmattmustangs
Maddmattmustangs
Post  bosshoss March 7th 2010, 1:08 am
I'm thinking mr. Kaase already did a pretty good job reshaping and engineering that chamber. Not sure I would be messing with that one.
In principal yes if you have a chamber that needs work you could do this.
I would spend my time in other area's where I could get a better bang for my time spent.
jmho.
dkp
bosshoss
bosshoss
Post  bb429power March 21st 2010, 2:53 pm
Yes, my engine builder (since I don't have the tools) completely re-constucted the chamber and bowls on one cylinder of a big chebbie boat motor. If its done right, it will work.
bb429power
bb429power
