grounding question
grounding question Empty grounding question
Post  Big block fox 339 March 7th 2010, 3:14 pm
This may be a dumb question im sorry if it is my car is almost finished I just like a few electical things my question is if your using motor plates do you still need to put a groud strap somewhere on the engine or will the motor plates ground it? I do some electrical work but not on cars it seem to me the plates would ground it
Big block fox 339
Big block fox 339
grounding question Empty Re: grounding question
Post  richter69 March 7th 2010, 3:34 pm
I like to run a cable from the batt to the chassis, and then a long one from the batt to the back of the cyl head..............or even to the bellhousing. Has always worked good for me this way.
Post  Big block fox 339 March 7th 2010, 4:56 pm
Thanks that's what il do.. also does anbody know where the small ignition wire that goes from the key to the starter solenoid is on a fox body
Big block fox 339
Big block fox 339
Post  BIGDOG466 March 7th 2010, 5:27 pm
richter69 wrote:I like to run a cable from the batt to the chassis, and then a long one from the batt to the back of the cyl head..............or even to the bellhousing. Has always worked good for me this way.
X2 Gotta listen to A+
BIGDOG466
BIGDOG466
