Plate V.S. Fogger
Plate V.S. Fogger Empty Plate V.S. Fogger
Post  511Fox March 25th 2010, 2:54 pm
On a small shot like 170-300 HP is there much difference between a fogger or plate Nitrous System Question
Anyone using the Nitrousaurus 10LB Nitrous Warmer/Cooler Question Suspect
What is your favourite Nitrous Supplier Question Suspect
Last edited by 511Fox on March 25th 2010, 2:57 pm; edited 1 time in total (Reason for editing : 2 more questions needed)
511Fox
Plate V.S. Fogger Empty Re: Plate V.S. Fogger
Post  Induction-Solutions March 26th 2010, 12:00 pm
The difference you'll see would be... The plate will hit harder then a direct port system. The direct port system will run the second half of the track even better then a plate (double the number of solenoids), the direct port system can be tuned per runner as needed (and is usually needed on a Ford the larger you go), the direct port may cost a little more up front, but save in the long run...
As for the Nitrousaurus, I have seen someguys use them. They seem to do the job but are kind of bulky..
As for nitrous supplier, I've heard some little company Induction Solutions doesn't do to bad of a job. Wink Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  Barney March 26th 2010, 1:12 pm
Both. If you have to use one or the other I prefer the plate for 1/8th mile, and the fogger for 1/4. I use the NX fire and ice heater and it works pretty good. Heats a cold bottle from 650-1000 in about 20 mins and keeps it there all day. I get to the track flip the switch and never worry about it. Its always at 1000 everytime i check.
Barney
Barney
Plate V.S. Fogger Empty Good Sense or Nonsense?
Post  511Fox March 28th 2010, 1:38 pm
Would it make sense if you knew you would be using N2O often (only to race at a sanctioned track) to build a little smaller CID with a smaller cam and mix a plate & fogger Question
Instead of building a E-85 547 with 12.5-13:1 CR build a 472-521 CID with a pump gas friendly 9.8-10.2:1 cr then add a Sniper plate (fixed 125 HP) and a 200-250 HP Fogger Question
Is the above Good Sense or Nonsense Question Suspect
No OR Twisted Evil Question
511Fox
