How long is the Kaase pump?
Is the Kaase pump any longer or shorter than a Melling HV pump?
jbozzelle- Posts : 3705
Re: How long is the Kaase pump?
Yes it is longer, if I were at home I would give U the measurments.
Thanks Rick. I want to make sure it fits inside the front sump of my Fox Body swap pan before I buy one.
I currently have a used HV pump on the shelf. It's the one with the shaft through the cover and just want to compare.
Which pan do you have? The ones with a 6.5" pump pocket are good to go.
jbozzelle wrote:Thanks Rick. I want to make sure it fits inside the front sump of my Fox Body swap pan before I buy one.
It IS the same length as the Cobra Jet pump which is longer than a rear facing pick-up "D" pump.
I should be good. I have a Moroso pan. The front sump is 6.5" deep.
Jon, My Kaase pump measured 6 1/2. And the HV Melling measured 6".
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» KAASE OIL PUMP
» kaase oil pump
» Is this a long or short water pump?
» Kaase oil pump
» KAASE OIL PUMP
» kaase oil pump
» Kaase oil pump
