Tranny lines
+6
blown473
NO FAIR
10 posters
Tranny lines Empty Tranny lines
Post  NO FAIR March 30th 2010, 9:07 pm
A friend of mine was telling me that he used teflon coated braided lines going to his tranny cooler. Is this necessary or can someone use just regular braided hose or even use steel and then adapt to braided?
Dave
Smile
NO FAIR
NO FAIR
Tranny lines Empty Re: Tranny lines
Post  jasonf March 30th 2010, 9:15 pm
Teflon should last longer but I have never heard of people having tranny lines deteriorate. I have just ran rubber lines or regular steel braided lines on every car I own with no problems.
Post  the Coug March 30th 2010, 9:32 pm
I like the teflon Braided lines they last a long time but are a little expensive to get made....
Post  cool40 March 30th 2010, 9:46 pm
the Coug wrote:I like the teflon Braided lines they last a long time but are a little expensive to get made....
x2 and kinda stiff and hard to work with. Smile
Tranny lines Empty tranny lines
Post  blown473 March 31st 2010, 8:51 pm
Regular braided line works fine. You can also use rubber hose thats for power steering or fuel.
blown473
blown473
Post  richter69 March 31st 2010, 9:44 pm
I've used them all..................the rubber hose with a clamp deal sucks though, was going into the water box one time and before I did I put it on the brake to put some heat in the converter.....................line popped off the cooler and made a hell of a mess............currently using teflon braided stuff.
Post  jones March 31st 2010, 10:40 pm
I like 3/8 hard line.
jones
Post  whatbumper March 31st 2010, 11:46 pm
I use heavy ole hydraulic line. Of course it is in the car with me so I am overly cautious.
Post  BIGDOG466 April 1st 2010, 5:57 pm
BIGDOG466
BIGDOG466
Post  DILLIGASDAVE April 1st 2010, 8:03 pm
For the low buck approach common rubber power steering pressure hose is usually safe in a lot of cases for trans lines as long as each joint is double hose clamped & the hard line (or fitting) has some kind of a flair/raised edge making it harder for the hose to slip off.
But I wouldn't use rubber fuel line, it's usually a lot thinner wall & less webbing than power steering hose. And if I remember correctly the rubber compound is different between the two hoses. I have seen rubber fuel line split when used as a trans line, but never seen the power steering stuff fail.
