10.5 x 29.5 section width
Kens429
10.5 x 29.5 section width Empty 10.5 x 29.5 section width
Post  Kens429 April 7th 2010, 5:43 pm
I'm trying to find out if anybody knows the "real" section width of Hoosier's 10.5 x 29.5 on a 10" rim. M/T's would he heplful also. I tried W's before, and they were way too wide. The Hoosier tech guy told me not to trust the catalog. My current Hoosir 9x30's measure 13" section width. Any help would be greatly appreciated.
Kens429
Kens429
10.5 x 29.5 section width Empty Re: 10.5 x 29.5 section width
Post  richter69 April 7th 2010, 6:46 pm
only numbers I could give would be with the W's...............
Post  Northwest outlaw April 7th 2010, 7:00 pm
P# 3062
Tire 29.5/10.5-15
Rim 10
SW 13.1
TW 10.2
Northwest outlaw
Northwest outlaw
Post  Kens429 April 7th 2010, 7:43 pm
I saw that on M/T's site, but wondered if the numbers were reality. If so, the "s" might be an option because I need a stiff sidewall. The car is a 3800 lb. stick car. The Hoosier has the same section width with 11.1" of tread.
Kens429
Kens429
Post  GTmustang April 7th 2010, 9:09 pm
The Tire store I deal with, Harlow Race Tire at Norwalk Raceway and Wayne MI, mounts and tests the tires themselves using the largest recomended wheel width for the tire and lists these revised numbers in their catalogs. They list the Hoosier 29.5x10.5x15 as 30.6"dia-96.2 circ-14.0 sec and 11.1 tread width when mounted on a 12" rim. The catalog says to subtract .4" of sec width for each inch that the wheel is narrower than 12", so that would make it 13.2" sec on a 10" rim. the M/T 29.5x10.5x15 is listed as 29.9"dia-94"circ-13.5sec and 10.2 on a 11" rim. So that would make it 13.1"sec on a 10" rim!. Hope this helps!
Gary
GTmustang
Post  whatbumper April 7th 2010, 10:22 pm
I'm not close to the car now but these are MT 29.5x10.5s tires mounted on a 12 inch wheel.
10.5 x 29.5 section width Dsc_0811
Post  Kens429 April 8th 2010, 10:13 pm
Thanks for the info. It helped a lot.
Kens429
Kens429
Post  f250mike April 10th 2010, 9:06 pm
I just went out and measured my 29.5/10.5-15 hoosiers. With a 10" wheel they have a 11.5" tread width.
Is the section width the overall width of the tire from sidewall to sidewall? If it is I can check it in the morning.
mike
f250mike
f250mike
Post  Kens429 April 12th 2010, 4:45 pm
f250Mike, yes sidewall to sidewall is the section width. That info would be great. Are you running the D06 or C11 compound? Which model number?
Thanks, Ken
Kens429
Kens429
Post  f250mike April 15th 2010, 4:43 pm
Ken, sorry for not getting back to you sooner. I have been coming home from work and going straight to the shop.
I have the D06 compound.
With 12psi the section width is exactly 14"
mike
f250mike
f250mike
