Water pump fitting
Water pump fitting Empty Water pump fitting
Post  OldRedFord April 14th 2010, 2:03 am
Where can I get the water pump fitting that screws in the side of the water pump on my 460? What size is it?
Water pump fitting 515514693_1817054930_0
OldRedFord
OldRedFord
Water pump fitting Empty Re: Water pump fitting
Post  bbf-falcon April 14th 2010, 8:28 am
Run a pipe tap in it and put a (barb)fitting in it. Smile
Post  chuck stevens April 14th 2010, 12:48 pm
3/8 NPT tap will fix it right up and, a brass nipple from your local hardware store will last forever. Smile
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  342g April 14th 2010, 12:55 pm
OldRedFord wrote:Where can I get the water pump fitting that screws in the side of the water pump on my 460? What size is it?
You talking about a radiator hose,? if so I have one you can have.
342g
342g
Post  OldRedFord April 14th 2010, 11:10 pm
Nope. The hole in the water pump where the heater hose goes. Ended up checking Lowes first. Got a 1/2 MIP x 5/8 barb fitting. Threaded right in.
OldRedFord
OldRedFord
