shifter question for TH 400 in 94 mustang
shifter question for TH 400 in 94 mustang Empty shifter question for TH 400 in 94 mustang
Post  cobra501 April 14th 2010, 3:11 pm
Bought a new TH400 w, JW bell from JW with reverse VB and brake. I know I need a shifter too match but do I get a shifter with the cable coning out front of rear. Rookie question, I know. Im really in Iraq For almost 4 years so I can look at the trans to determine and I want to order the shifter. Thanks Royce
cobra501
cobra501
shifter question for TH 400 in 94 mustang Empty Re: shifter question for TH 400 in 94 mustang
Post  Treeyasoon April 14th 2010, 3:26 pm
It depends on how you want to route your cable and where the cable needs to penetrate the floor. A rear exit will usually use a little longer cable since you have to make the turn to route it back toward the front of the car. No right or wrong answer IMO.
Last edited by Treeyasoon on April 14th 2010, 3:26 pm; edited 1 time in total (Reason for editing : typo)
Treeyasoon
Treeyasoon
Post  cool40 April 14th 2010, 9:38 pm
Treeyasoon wrote:It depends on how you want to route your cable and where the cable needs to penetrate the floor. A rear exit will usually use a little longer cable since you have to make the turn to route it back toward the front of the car. No right or wrong answer IMO.
x2,i think if a shorter cable was used a rear exit would work pritty well.i just got my tci with a front exit and a rear with short cable woulda worked better for me.i think the rear exits were made for rail's? Smile
Post  cobra501 April 14th 2010, 10:59 pm
thanks guys, I think your right rear exit for rail .
cobra501
cobra501
Post  whatbumper April 14th 2010, 11:01 pm
You just want to be able to make big turns in the cable. A new cable will turn pretty sharp but will not work as well when it gets a little older. I use a front exit in our fox body and have zero troubles. In my old Maverick i had a rear exit cable and it worked better but I had the shifter mounted at an angle pretty high over the tunnel.
Post  DILLIGASDAVE April 15th 2010, 12:18 pm
A rear exit cable shifter does sometimes work better on full chassis door cars (vs a front exit) in situations where the driver prefers a relatively high shifter mounting/placement & also if there is a good amount of engine/trans setback. This combo can sometimes really put a short front exit shifter cable in a bind trying to make the two tight curves.
On the other hand a high shifter placement can actually can help the rear exit cable because only one looping bend is needed. And after the cable exits the rear & loops down & back forward the cable height is usually pointing directly right at/around the shifter arm height a lot of the time.
Precision Performance Products makes one of the nicest drag racing auto shifters I have seen. Super light weight & thin, damn nice.
http://www.precisionperformance.com/
Post  cool40 April 15th 2010, 1:55 pm
Dave that's what i was thinken when i was getting the tci in my car.it's a door car like your sayen and i mounted it pritty high too and rear exit woulda worked better with less bending.when i was looking to buy one i noticed the rear exit tci had a longer cable,figured it's for a rail,wish i'd called to see if it was offered with a shorter cable. Smile
Post  cobra501 April 15th 2010, 2:28 pm
The shifter Im looking at has a 5 foot cable. Is this considered sort or long?
cobra501
cobra501
Post  cool40 April 15th 2010, 8:28 pm
thats a standard size,is it front or rear exit? Question
Post  cobra501 April 17th 2010, 3:03 pm
Im looking at the TCI 618332 on Summitracing. It comes with a 5ft cable. So far his one fits my needs and likes unless someone has a better choice I can look at. thanks
cobra501
cobra501
