Windage Tray Question
Anyone know the brand/part number of the windage trays that bolt to the 2-4 main studs, For the rear sump pan? (Moroso pan).
Thanks Ed.
Thanks Ed.
ROAD RAGE- Posts : 229
Re: Windage Tray Question
ROAD RAGE wrote:Anyone know the brand/part number of the windage trays that bolt to the 2-4 main studs, For the rear sump pan? (Moroso pan).
Thanks Ed.
Canton sells a screen type and MPG HEADS sells a 1/2 solid type like the FRPP small block ones.
i use a mildon one
so far it seem's to work good
it was on my stock block and now on my svo block
i will see if i can find a part# for ya if ya want
jesse- Posts : 447
Thanks Randy/Jesse for the info..
just for the record. For some reason Summit kept sending the wrong one. (2) third time charm. they sent the Milodon #32227 Solid louvered for rear sump $59.95. Looks and fit's real good (no cutting required). Very satisfied.
Thanks Guys..........
thats the one
so far i like it
so far i like it
jesse- Posts : 447
» windage tray
» Windage tray!!
» Windage Tray
» Windage tray
» Does a high volume oil pump necessitate a high volume oilpan?
» Windage tray!!
» Windage Tray
» Windage tray
