Ford factory ignition modules
+6
darrin1999
72mav
AZFairlane
chuck stevens
10 posters
Identified by the color of the strain relief plastic around the wires.
RED--Dura Spark I
WHITE--Dura Spark II (with cranking ignition retard).
BLUE--Dura Spark II (coil current ALWAYS on !, WILL start if starter is bumped)
YELLOW--Dura Spark II (dual mode, 3 connectors,Baro sensor)
GREEN
OR
BLACK--Early solid state ignition.
BROWN--EEC system.
RED--Dura Spark I
GREEN
OR
BROWN--EEC system.
Re: Ford factory ignition modules
Chuck,
You wouldn't happen to have a list or a link to which years and which cars had each of these modules, would you?
Thanks,
Joe
Thanks,
Joe
AZFairlane- BBF CONTRIBUTOR
BTW, what year did the Dura-Spark ignitions begin??
Thanks.
Al
Thanks.
Al
72mav- Posts : 1081
Personally, when using a production Ford type ignition, I prefer the remote mount "thick film" as on inline 6 cylinder trucks or 94 Mustangs.
A STANDARD points distributor will trigger them.
Last edited by rmcomprandy on February 14th 2020, 12:22 pm; edited 1 time in total
1974... i believe duraspark 2 1975 or 76Al Martin wrote:BTW, what year did the Dura-Spark ignitions begin??
Thanks.
Al
darrin1999- Posts : 20
Which one of these are used in the MSD units?
Wow, I was just fixing to ask about a diagram for a duraspark, thanks!!IDT-572 wrote:
95lightiningguy- Posts : 570
rmcomprandy wrote:Personally, when using a production Ford type ignition, I prefer the remote mount "thick film" as on inline 6 cylinder trucks. A STANDARD points distributor will trigger them.
Can you show how to set that up?
Keith
res0rli9- BBF CONTRIBUTOR
95lightiningguy wrote:Wow, I was just fixing to ask about a diagram for a duraspark, thanks!!IDT-572 wrote:
Your welcome
res0rli9 wrote:rmcomprandy wrote:Personally, when using a production Ford type ignition, I prefer the remote mount "thick film" as on inline 6 cylinder trucks. A STANDARD points distributor will trigger them.
Keith
Can't show it but, I think I can tell you ...
First ... use a relay for the power because the "key-on run" wire in an older Ford will not carry enough current.
The poles of a 4.9L six cylinder or 94/95 5.0 L Mustang thick film, (TFI), divorced ignition are numbered: sometimes # 6 is the ground so, simply reverse the order on those.
1 = ground
2 = coil (-)
3 & 6 = tied together and go to the switched 12 volts through the relay and
that connection also connects to the coil (+)
4 = blank
5 = points (be sure to disconnect the condenser)
MSD Schematics ALL
https://www.mpsracing.com/instructions/MSD/wiringManual.pdf
Might deserve it's own sticky?
supervel45- Posts : 4499
» Factory EFI ignition
» Ford factory center caps
» Ford 1100ci factory engine
» Ford Factory Drag Mustang
» ? on a factory dual quad big block ford engine
