Crank pilot
+6
D. Sea
feetfirst
ThndrChkn
342g
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Crank pilot
Does anyone know what size crank pilot is on the steel 429 truck crank
, I'm hoping it is 1.375, but I haven't measured it.
342g- BBF CONTRIBUTOR
Re: Crank pilot
mine is 1.850,sorry .i dont know about all them.what you got goen on?
Re: Crank pilot
I believe all of the early stuff has a 1.850" pilot size. IIRC, after 1972 is when they went to the smaller 1.375" pilot size.
Doug...
Doug...
ThndrChkn- Posts : 2216
Re: Crank pilot
Then I'M screwed. ,...... does anybody know where I can get one of the shims, or whatever they are to use a 1.375, in a big pilot size?
Re: Crank pilot
342g wrote:Then I'M screwed. ,...... does anybody know where I can get one of the shims, or whatever they are to use a 1.375, in a big pilot size?
#529761 - TCI .....
feetfirst- Posts : 139
Re: Crank pilot
Harold,
If you have access to a Lathe, make one
D. Sea- Posts : 2768
Re: Crank pilot
Easy to make Harold,
Re: Crank pilot
x2,almost anything will work for it.any machine shop could hook you up in a few minutes.bbf-falcon wrote:Easy to make Harold,
Re: Crank pilot
I got a lathe we can GIT-R-DUN , gonna rain all damn weekend
BIGDOG466- Posts : 265
Re: Crank pilot
I called Coan, one of the tech guys said to use it as is, just put it together, and tighten the flex plat to the convertor, and go with it, you guys agree, or should I pull it back apart.?
Re: Crank pilot
Get with Mike (BigDog466)....he can hook you up....all you need is enough room between the front of the converter and the crank to slide the sleeve in....don't have to pull it all out. He is right....gonna' rain all weekend.
P.S.-I have ran without one before for a while...prolly not a good idea though...lol.
Treeyasoon- Posts : 759
Re: Crank pilot
Has he got a shop, or someplace to do it, I would tow it to his place?
Re: Crank pilot
I don't think you would need to take it there....just take some good measurements with a set of calipers and he should be able to fix you up....or at least get you close enough that a little polishing will make it slip in....he is pretty sharp.
Re: Crank pilot
you dont want to run it without the ring on it.the best thing that would happen is the bushing in the pump gets beat out,then the leaking starts,and you dont even want to know the rest.
Re: Crank pilot
cool40 wrote:you dont want to run it without the ring on it.the best thing that would happen is the bushing in the pump gets beat out,then the leaking starts,and you dont even want to know the rest.
Wonder why coan would tell me that, they piss me off.
Re: Crank pilot
I won the Bash 2 years in a row without one in my Mustang Harold . I used the one I had in the Tbird , i just started all 3 bolts in the convertor and flywheel without snugging them down and rotated it to try to center as best as possible .Then tightened them . I don't recommend it ,but it can be done.
56Tbird- BBF CONTRIBUTOR
Re: Crank pilot
i'm sure an sfi flexplate would help if you did run it like it is,less flex,but it's too easy to fix to not.i dont know why any trans company would tell you to run it,unless they would like to sell you some parts after you shit can your's.
Re: Crank pilot
I sent a message to big dog, Maybe he will make me one, then I am going to e-mail coan, and tell them what I think of their info.
Re: Crank pilot
Who did you talk to up there Harold?
Re: Crank pilot
Tree,
It wasn't Art, what do you get dealing with a bunch of chebby guys------- nutun
Harold's all set up just come and get it.
Re: Crank pilot
Be there tomorrow, you guys are grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrreat., be there at "sex"
Re: Crank pilot
I'm pretty sure he said his name was Craig, "Tree"
Re: Crank pilot
I've dealt with Craig quite a few times over the years...it kinda surprises me that he would tell you to run it like that. Sounds like Mikey has you fixed up...you better be sure to give him a big wet kiss.
Re: Crank pilot
I don't know about all of that, I will buy him a beer or ten though.
Re: Crank pilot
Harold, I have never ran a pilot spacer. Been running 598" BBF/PG combos since '96 and have never had an issue.
Although I have ran others, Coan has always been my converter of choice.
Curt- Posts : 2791
Page 1 of 2 • 1, 2
» crank pilot delemma
» Early 429 crank pilot diameter
» Part number for a glide to BBF crank pilot adapter....
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» aluminum crank pulley and a crank trigger
Page 1 of 2
