Forged Crank (3.850)
deerhunter3814
cdbearde
Is any company making Forged 460 cranks? If not, has anyone ever took one of the forged 429 cranks and made a 3.850 stroke, or is that even a possibility?
cdbearde- Posts : 18
Re: Forged Crank (3.850)
Its possible to make a 429 steel crank into one, if you go to a BBC 2.2 journal size.
Are these cranks hard to find and what is the largest stroke that can be ground out of them? 4.125 or 4.150?
deerhunter3814- Posts : 144
They are not real common, but not impossible to find either. With a chevy journal you can probably get around 3.9-4.0 stroke out of one. If your looking for a 4.15 is probably cheaper and easier to just get a SCAT or similar off shore one.
You don't hear of many stock 3.850 cranks breaking........ They tough
Yes it can be done and is done a lot in truck pull setups and small CID race engines. You need to find a 429 out of a F600-700 truck. The snout will also have to be redone.
can be done , got one thats done , the most stoke that can be done is 3.880 and lower to get a certain big bore short stroke for cube limit.
DanH- Posts : 1081
IDT-572 wrote:You don't hear of many stock 3.850 cranks breaking........ They tough
I agree
D. Sea- Posts : 2768
I run a 4.5 bore, and I want to run a small, but larger stroke than a 3.850 but it needs to be an OEM crank. I will spin it pretty hard. I am going to change my career, no more mud.
Blake,
Finally tried out the shift pattern that we discussed, it worked real good, it felt like it hooked up better, that's a lot better. Thanks for the heads up. Took first place Saturday.
Blake,
DanH wrote:can be done , got one thats done , the most stoke that can be done is 3.880 and lower to get a certain big bore short stroke for cube limit.
If a 3.880 is the largest stroke, then going past 3.850 would not be worth the cost of the custom pistons. IMO
deerhunter3814 wrote:I run a 4.5 bore, and I want to run a small, but larger stroke than a 3.850 but it needs to be an OEM crank. I will spin it pretty hard. I am going to change my career, no more mud.
Blake,
Glad it worked for you........... Congrats on the win...........
why would custom pistons be needed ? OTS pistons are easy to get. know Probe got them .deerhunter3814 wrote:DanH wrote:can be done , got one thats done , the most stoke that can be done is 3.880 and lower to get a certain big bore short stroke for cube limit.
DanH- Posts : 1081
Dave, What would C.I be w/that crank and 6.7 rod w/.030 overbore?dfree383 wrote:Its possible to make a 429 steel crank into one, if you go to a BBC 2.2 journal size.
DanH wrote:why would custom pistons be needed ? OTS pistons are easy to get. know Probe got them .deerhunter3814 wrote:DanH wrote:can be done , got one thats done , the most stoke that can be done is 3.880 and lower to get a certain big bore short stroke for cube limit.
I was just assuming that it would be a custom deal, if it is not then this might be an option for next year. Thanks for the info. Now to start looking for a crank.
IDT-572 wrote:deerhunter3814 wrote:I run a 4.5 bore, and I want to run a small, but larger stroke than a 3.850 but it needs to be an OEM crank. I will spin it pretty hard. I am going to change my career, no more mud.
Blake,
Thanks Blake, I have a new deal up my sleeve, I'll give you a heads up later.
With some questions probably.
I've got one,it's in a kit deal from Engine systems a few yrs. back. I don't know the exact stroke of the crank.(was suppose to be a 472 C.I) it has Crower 6.7 Billet rods and .030 Venolia Domes. If anyone needs it, let me know. I have new rings,M/R bearings and the crank is fresh
bbf-falcon wrote:I've got one,it's in a kit deal from Engine systems a few yrs. back. I don't know the exact stroke of the crank.(was suppose to be a 472 C.I) it has Crower 6.7 Billet rods and .030 Venolia Domes. If anyone needs it, let me know. I have new rings,M/R bearings and the crank is fresh
472, on what bore? We might figure it that way.
I was hoping the 429 crank would go at least 4.0.
If you can figure out the stroke, please let me know.
.030 would be 4.390 borebbf-falcon wrote:I've got one,it's in a kit deal from Engine systems a few yrs. back. I don't know the exact stroke of the crank.(was suppose to be a 472 C.I) it has Crower 6.7 Billet rods and .030 Venolia Domes. If anyone needs it, let me know. I have new rings,M/R bearings and the crank is fresh
Great info. guys.
bbf-falcon wrote:.030 would be 4.390 borebbf-falcon wrote:I've got one,it's in a kit deal from Engine systems a few yrs. back. I don't know the exact stroke of the crank.(was suppose to be a 472 C.I) it has Crower 6.7 Billet rods and .030 Venolia Domes. If anyone needs it, let me know. I have new rings,M/R bearings and the crank is fresh
Sounds like a 3.9 stroke 3.9X4.39 comes in right at 472.
