Need some opinions/ Long
+7
Mark Laczo
512Fairlane
torkair
Tore
11 posters
Need some opinions/ Long Empty Need some opinions/ Long
Post  Tore May 1st 2010, 7:44 pm
Over the winter I had to rebuild my 508 to 514 ci. I put in domed pistons now have a 14.5 to 1 comp up from 12 to 1. More radical roller cam.Ported P-51 heads by Charlie.This engine was in my Torino that weighed 4300 with me in it. Well I took the whole drivetrain and installed it in a car that is 850 pds lighter than what I had.
The best the Torino ran was a 10.299 at 131. Well the best I could get out of the new car last night was a 10.22 at 128 mph. I am puzzled like WTF.
I used the same 1050 dominator as before, different dist, 28 deg. total adv in by 2500 rpm. This car is running a Holley black pump with a 5/8 line to the reg. I did notice it has only one 5/8 line to the pump. The fuel pressure gage is not visible because its on the regulator. That is one thing I am changing this week .
This guy ran a 534 ci with some Blue Thunder Heads and all he ran was 10.20s. I questioned him about the fuel pump size and he said it was fine. But I am thinking that is my problem.
I also have a 1150 Quick Fuel carb here ready to bolt on. Need some opinions and suggestions guys.
Thanks Tore Idea
Last edited by Tore on May 1st 2010, 7:56 pm; edited 1 time in total (Reason for editing : fuel line size wrong)
Tore
Tore
Need some opinions/ Long Empty Re: Need some opinions/ Long
Post  torkair May 1st 2010, 7:46 pm
What is the rear gear in the new car verses what was in the torino?
torkair
torkair
Post  Tore May 1st 2010, 7:55 pm
The Torino had 4.11s with 28.8 tall tires and the new car has 32" tall tires with 4.30s. ALso the single line to the pump is a 5/8 single line. Its one of those fuel lines that looks like a garden hose.
Tore
Tore
Tore
Post  richter69 May 1st 2010, 8:12 pm
converter stall? trans type? trap rpm?
Need more f/p for sure
Post  Tore May 1st 2010, 8:21 pm
Leaving on the brake it was stalling at 5k, its a C-6 and the trap rpm I cant really say I was a little uneasy in the car it was a new ride and is taking a little bit to get used to.
In the Torino it would go thru the traps at 6700.
Tore
Tore
Tore
Need some opinions/ Long Empty What's the 60 ft?
Post  512Fairlane May 2nd 2010, 2:40 am
I'm running the same pump with 1/2" lines. Still untouched heads, 12:1, and a much smaller cam. I think your old cam was larger than mine. Is it a dog out of the hole? What's the 60ft? What pump where you running in the Torino?
512Fairlane
512Fairlane
Post  Tore May 2nd 2010, 7:15 am
The 60fts were in the low 1.4s and I was running a Holley Volumax Pump I think it a 180. Car seems to pull strong all the way down the track.
Tore
Tore
Tore
Post  bbf-falcon May 2nd 2010, 8:43 am
Tore, You have something other than fuel causing the problem IMO. The 466 I built for Mike(GoinPostal) is only 12.1. It has a 110gph Holley Blue. It weighs more than your new ride and went 10.14 off the Trailer w/no tuning. And the p51's are out of the Box. Are you sure the Octane is high enough for the compression. You should have no less than 112 octane. Can you post a time slip so we can study it. It might be blowing through the converter. confused
Post  Tore May 2nd 2010, 8:48 am
I am running 112 octane, I just got the convertor back from Broader Perf. and told him of the increased HP and Jay said I should be fine with it. I will have to get the slips later and try to get them up.
Tore
Tore
Tore
Post  bbf-falcon May 2nd 2010, 10:34 am
Tore,W/c6 and a car that light,your 60' should be in the mid 1.30 range. Does the car get the rpm's quick or does it seem flat?I set Mike's timing at 30 total so you should be in the ball park at 28.
Need some opinions/ Long Empty New Car
Post  Mark Laczo May 2nd 2010, 11:21 am
Tore ,
This may sound like a dumb question/idea but did you weigh the new car to get the 850 lbs less or did the guy selling it ? Maybe a trip to the weigh scale will help some ?
Later Mark
Mark Laczo
Mark Laczo
Post  Tore May 2nd 2010, 11:52 am
The car acelerates real quick. But looking at the time slips its the same 60 fts that the torino did. I weighed the car at the track thats how I knew the car was lighter.
Tore
Tore
Tore
Post  bbf-falcon May 2nd 2010, 11:57 am
I tried to call Tore Smile
Post  Tore May 2nd 2010, 2:30 pm
I was wrenching
Tore
Tore
Need some opinions/ Long Empty Was your fuel pump big enough?
Post  512Fairlane June 27th 2010, 6:22 pm
Tore have you found anything out with your Falcon. Was the pump large enough?
512Fairlane
512Fairlane
Post  Tore June 27th 2010, 6:34 pm
Well it aint the fuel pump. I have a new convertor coming this week. I ran Friday night and it ran 10.09 130.?? the best. My 60 ft sucks . 1.43 using the brake. I got a converter from Lenny at Ultimate Converters. He feels I am driving thru the old one in the Torino. So I am pulling the engine and Tranny tomorrow and should have it back to gether by Saturday.
I also swapped out the ignition box no difference but my coil took a dump last week. Everytime I turn around something isnt right on the car. Should have just kept driving the Blue Torino would have been money ahead and alot less frustration. I think Rick Brown is in the same boat as me by the email I got from him yesterday. Misery loves company come on in.
Tore
Tore
Tore
Post  bbf-falcon June 28th 2010, 5:14 am
I have a new regulator to try on Tweety this week. We (both of us) will get this right before Norwalk Tore.I think the converter will solve yours. Seems quite a few of us have been fighting demon's this year.
Dan-2 blown engines and a crash
Tore and the Falcon ET problems
Me w/Gear and fuel delivery problems
Harold PG issues,then Sat.nite he thinks he twisted front shaft
Hope it's run it's path Evil or Very Mad
Post  Mark Miller June 29th 2010, 12:29 am
Rick and Tore,
I here you been going thru crazy shit with my car also.It wouldn't start first of May tested pick up coil showed fine.l changed coil started up,sat for a few weeks wouldn't start again tested MSD box didn't test like it should have MSD tech said change coil.I put the same coil on i took off before and thought was bad fired right up.June 12 th wouldn't start again changed back to the other coil fired up.Yesterday wouldn't start again with either coil,borrowed a good MSD box off a buddy still nothing.I checked pick up coil with ohm meter nothing,Auto Zone had a new pick up coil checked it just to be safe.Put it in today fired up after a few set backs last night,broke the collar on the bottom of the distributor didn't have another one luckily my cousin had one.
Later Mark
Post  bbf-falcon June 29th 2010, 8:36 am
Been a crazy year for a bunch of us Evil or Very Mad
Post  Mark Miller June 30th 2010, 12:41 am
Rick,
You're not kidding looking forward to Norwalk and your car running some good numbers.I might try to take my car to Thompson the Saturday of the Ford race at Norwalk if i have the money.I hope to see you and Tore at Norwalk Sunday morning.
Later Mark
Post  BOSS 429 July 1st 2010, 1:45 am
HOWS IT RUNNING NOW?
Post  bbf-falcon July 1st 2010, 4:59 am
Put a new regulator on last night.Going to track Friday nite. Let you know Sat. Wish we just a little luck for once this year. Smile
Need some opinions/ Long Empty punp
Post  dr's wife racing July 1st 2010, 12:04 pm
I ran one of the blackpumps on my old car with a 514. It ran mid 9's with no problem I eeven sprayed it a few times and ran low 9's.I think the punp should be fine as long as it is in good working order.
dr's wife racing
dr's wife racing
Post  bbf-falcon July 1st 2010, 1:06 pm
Yea,imo guy's go way overkill on pumps like anything else,they think bigger is always better Rolling Eyes The ole Maverick had a 110 blue pump when it ran 9.80's and My friends 850hp FE runs a Holley black pump at 9.0's .
Post  res0rli9 July 1st 2010, 2:22 pm
bbf-falcon wrote:Yea,imo guy's go way overkill on pumps like anything else,they think bigger is always better Rolling Eyes The ole Maverick had a 110 blue pump when it ran 9.80's and My friends 850hp FE runs a Holley black pump at 9.0's .
850hp FE.... care to share some details
