Cutting for springs/pc seals ?
I bought the cutters to do it, do you guys have any tips like what kind of oil to use ect ? The spring seat cutter is 1.550 od .630 id and the seal cutter is .531
nuclearcobra- BBF CONTRIBUTOR
Re: Cutting for springs/pc seals ?
no oil just cut it dry.......should be carbide tool and works better without oil.....
the Coug- Posts : 3055
In addition to what Coug said, turn it slow and don't let it chatter. If it chatters,,,, stop,,,,punt,,,,and start over.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
Thanks guys, also does the same technique apply to port matching iron heads, use the carbide burs dry ?
what all tools are all involved in cutting your heads?
138- Posts : 1593
it is one tool or mine is, it cuts the spring seats and trims the guides for pc seals all at one time, mine has 11/32 guide for ford heads / sbc heads or 3/8 for BBC heads. I have one for 1.550 springs and one for 1.625 springs, also have a Boss cutter so you can cut rocker stud bosses for guide plates and studs...... use a 1/2 drill or put it in a drill press and set the depth.... or I use a bridge port for mine.... always cut them @ 50 rpm so not to chatter or gouge the tool.....
thanks.. now where do you get these?
138- Posts : 1593
http://www.autozone.com/autozone/catalog/accessories/accessoriesShelf.jsp;jsessionid=A8811ECDF406993978B87F04D9B29DED.diyprod1-b2c2?itemId=1582-10&parentId=&displayName=Valve+Spring+and+Guide+Cutter¤tPage=1&navValue=101582&categoryDisplayName=&_requestid=891103
Comp cams has them also. do some looking and you might be able to find them cheaper....
I bought mine from summit its the howard cams brand cutters i bought the spring seat cutter 1.550 od .630 id then the seal cutter for.531 dia The seal cutter and arbor was $63 the seat cutter/arbor was $60+17 for the arbor. Competition products had them for $44+13 seat cutter/arbor and 50 for the seal/arbor cutter. The reason i went with summit racing is because the milodon megaflow valves i wanted were on back order from competition products and summit had them in stock. I also got a 4 set of carbide burs, 92 piece cartridge roll kit ,kay roll kit and a 56 piece surface recondition kit. So i'm gonna give it a try with the victor portmatch on my c8 heads, i hope i dont butcher them as these heads are fully ported now but were matched to a stealth intake and the ports look like glass. It must take years and years of porting to do that but i'm gonna give it a try anyway and i'm only doing the portmatch but still a little paranoid so i'm gonna grind on a few small ford iron heads first to get the feel for it so wish me luck i gotta run down Melvin some how
Crane
Crower
CompCams
Isky
Bullit
Summit
Jeg's
Howards
K-Line
Silver Seal
Regis
Goodson
And just about any company who sells cylinder head rebuilding tooling.
Crower
CompCams
Isky
Bullit
Summit
Jeg's
Howards
K-Line
Silver Seal
Regis
Goodson
» Fly cutting pistions
» Back cutting
» Coil springs or Leaf springs?
» cutting c4 bellhousing
» Fly cutting pistons
» Back cutting
