looking for NICE set of aluminum heads!
342g
Jeremiah
Trying to get everything out of my combo. I have a set or real nice procomps on the car now and have been into the 9s. But im thinking about trying a different head to compare.... Might sell or so dome trading with my PCs. Post up what you got..
Jeremiah- Posts : 157
Re: looking for NICE set of aluminum heads!
I think Richter69, or the Coug., would be glad to trade with you, they have been looking for a good pair of Pro Comps.
342g- BBF CONTRIBUTOR
I'm being serious here but thanks for the free bump.
ck these out ..... brand new
https://www.429-460.com/stuff-for-sale-f1/frpp-scja-heads-t4652.htm?sid=3b0a882f1089f0fc283f6c378e111d04
Bruno always lookin out. Thanks man!
the only problem you have going to the SCJ heads is you have to get different pistons or have your notched... They are not factory valve placements....... and if you have domed pistons you have to change them out......
the Coug- Posts : 3055
my heads aint for sale or trade right now lol................
I thought they were, my bad.
You need a good set of TFS streets ,Edelbrocks,or First generation Alum. CJ's . You can use these heads w/o changing anything else.
I don't want to change pistons or anything. Just heads. Ill start with a cam swap. Any good ideas on what cam?
Yep, talk with a cam grinder.... but if your going to change heads you'll want to get it speced for the heads your going to use. no sence getting a cam ground for the procraps if your going to be switching to a better head.
Your right. Guess its time to spend more $$$$$$$ lol!
TTT!.. Still looking. What you got?
i still have the motorsport heads with intake, rockers, push rods, guide plates, a few sets of pistons depending on your bore size. heck i'll even throw in a set of solid roller lifters. for 3000.00. need to get the new thor heads put together
fatal addiction- Posts : 433
3k... Im trying to spend a little less. But ill see what I can swing
i know 3k is alot but if u think about it it's actually pretty cheap for everything what bore is your motor? what crank u runnin? if i had a set of pistons it would make the deal alot better if i don't we could work out a little better deal.eric
the only thing Fatal attraction he has factory valve pierce point pistons..... and does not have a block that will bore any where thats size......if he changed that then every thing he has is useless nothing will fit from his engine or car...
i have a set of 4.390 pistons for a-heads
3k I'd sell my street heads................will work with the pistons you already have.............
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» WTB ALuminum Heads
» ISO Aluminum Heads
» Looking for aluminum heads
