cam lift question
Maddmattmustangs
95lightiningguy
fatal addiction
cam lift question
how do u figure out actual lift of the cam shaft after the rocker ratio?? sorry if it's a dumb question. thanks
fatal addiction- Posts : 433
Re: cam lift question
Whaaa what was the question I was distracted by the avatar pic.
95lightiningguy- Posts : 570
gross lift is lobe lift x rocker ratio.
example would be .358 x 1.73=.619 then you can subtract the amount of lash setting you have in a solid valvetrain.
Hope this helps alittle bit.
btw i want you avatar pic
That's one sick bike!!!
cam lobe lift X rocker arm ratio = valve lift. Then - lash = total lift (not always necessary to factor in lash).
Or the lift the cam card says is for the valve lift divided by the rocker arm ratio = lobe lift.
Simple enough, the rocker arm is offset to give it extra lift and leverage.
bb429power- Posts : 3129
WOW, their is a motorcycle in the avatar.
tiger- Posts : 272
Nice stank...I mean motorcycle.
If every girls face looks like that in your avatar...the world will be a better place.
........as long as it is clean.
Anyways back to topic.
Dr.Ford- Posts : 130
what motorcycle????
procharger 528- Posts : 45
Wait, there really is a motorcycle in there? I was just kidding. but i wouldn't want to kiss that face Dr. Ford. Well on the cheeks not the lips.
» Will Miller mid lift rockers 1.8 be good for a solid roller 272 Dur. .688 lift?
» Cam duration @.200" lift
» Kasse P 51 heads
» 4 inch lift on a 79 f-150
» Kasse P 51 heads
