Flex Plate bolts
Flex Plate bolts Empty Flex Plate bolts
Post  hirock May 11th 2010, 11:29 am
460 C6 went to check torque converter to flexplate before installing in trans. and the flex plate bolts are hitting the coverter body and not letting converter mounting feet to mate to flexplate its holding it off less than a 1/4 inch. If I use arp flexplate bolts which I have been told are not as thick and they still hold me off a little can I use a shim to make up difference as long as I have my correct movement
hirock
hirock
http://jimmyshirock@bellsouth.net
Flex Plate bolts Empty Re: Flex Plate bolts
Post  Treeyasoon May 11th 2010, 12:26 pm
I wouldn't see why not...as long as the converter can still come forward 1/8" before it touches the shims.
Treeyasoon
Treeyasoon
Post  bbf-falcon May 15th 2010, 11:29 pm
Are U sure U don't have the FW on backwards Question
