Header problems
Header problems Empty Header problems
Post  J R August 20th 2009, 4:57 pm
Got the passenger side in good but the driver side is looking real hard.The steiring wheel section is right in the way so we took it out an we don't know how to get it pass the headers. thanks.
J R
J R
Header problems Empty Re: Header problems
Post  dfree383 August 20th 2009, 5:44 pm
If it's a fox body you will probably need to remove the steering shaft, install the headers and then reinstall the shaft.
Post  bruno August 20th 2009, 5:53 pm
which headers are you using jr ? ..... engine mounts or plates ??
http://WWW.CKRME.COM
Post  stangr8cr August 20th 2009, 6:50 pm
You may have to cut out a section of the tube and rotate it a little and reweld. We had a similar issue with some Hooker Super Comps in our fox.
Boo Boo
stangr8cr
stangr8cr
Post  J R August 20th 2009, 8:02 pm
dfree383 wrote:If it's a fox body you will probably need to remove the steering shaft, install the headers and then reinstall the shaft.
Yes it's a foxbody
J R
J R
Post  J R August 20th 2009, 8:03 pm
bruno wrote:which headers are you using jr ? ..... engine mounts or plates ??
Hooker headers
J R
J R
