Starter wont engauge flexplate
Starter wont engauge flexplate Empty Starter wont engauge flexplate
Post  OldRedFord May 13th 2010, 5:26 pm
Im trying to start up the F100 for the first time. When i turn the key the starter makes a funny noise for a second and then just free spins not grabbing the teeth on the flexplate. All the teeth on the flexplate are still there. I even turned the motor a bit by hand to get a different spot on the ring gear...still a no go.
I took the starter out and hooked it right to the battery and it spun and the gear popped to the end of the shaft like it is suposed to.
Could the starter be messed up in a way that when out of the vehicle it acts like its good, but when its mounted its not?
OldRedFord
OldRedFord
Starter wont engauge flexplate Empty Re: Starter wont engauge flexplate
Post  69F100 May 13th 2010, 5:55 pm
YES check the gear I have seen them slip when in engaged look fine floor testing it but wouldn't crank my gear was busted it had a hair line crack in it
Post  rmcomprandy May 13th 2010, 5:58 pm
IF ... the enguagement is fine then the sprag inside the bendix is probably slipping.
Not a common problem but, it does happen.
Post  OldRedFord May 13th 2010, 6:25 pm
Is there some "wiggle room" with the starter loosely bolted up? Maybe it needs to move towards the frame rail a tiny bit?
OldRedFord
OldRedFord
Post  OldRedFord May 13th 2010, 9:07 pm
I got it. Now I got a fuel leak at the carb to fix.
OldRedFord
OldRedFord
Post  bbf-falcon May 13th 2010, 11:10 pm
Are you sure you have a starter for a Auto. If its for a stick it won't engage far enough to catch the flywheel.
Post  342g May 13th 2010, 11:24 pm
Was that your problem Rick?
342g
342g
Post  bbf-falcon May 13th 2010, 11:40 pm
On the one my brother gave me it was. I might take it tomorrow and get the Face turned down so it will set back far enough to catch the FW. Evil or Very Mad
