Starter problem/ wont shut off
Starter problem/ wont shut off Empty Starter problem/ wont shut off
Post  Tore September 26th 2019, 6:42 pm
I know this is a 429/460 forum. But I have a 61 galaxie with a 427 TP. I replaced the solenoid as it wouldn't get any voltage to the starter. I have put in 2 new solenoids and now when I turn the key off it just keeps spinning the engine over. Any ideas would be helpful.
Thanks Tore
Tore
Tore
Starter problem/ wont shut off Empty Re: Starter problem/ wont shut off
Post  norm September 26th 2019, 8:07 pm
Does the switch wire still have voltage when key is released? Ignition switch maybe shot
Otherwise i've seen a low battery make solenoids stick then jump/battery charger and solenoid would work fine.
norm
norm
Post  stanger68 September 27th 2019, 12:12 am
Most likely the ign switch. I’ve seen 2 different 68 mustangs do the same thing.
Post  Tore September 27th 2019, 9:55 am
stanger68 wrote:Most likely the ign switch. I’ve seen 2 different 68 mustangs do the same thing.
Thanks Guys it looks like the ignition switch.
Tore
Tore
Tore
Post  stanger68 September 27th 2019, 10:55 am
I have always chalked this one up as cheap aftermarket parts.
