Starter Problem
Starter Problem
Had my starter fail at the track Friday night . . . . was using late model (F2TU-BA) Auto Trans starter.
After pulling the starter I found that the nose had cracked and the support bearing/bushing had blown out. Needless to say this left the shaft flopping around in the housing.
Of course it may also be possible that the bushing failed first and the broken casting was caused by the shaft flopping around.
Engine is a 14.7:1 632, should I chalk this up to a bad casting, or am I destine to have this problem again if I use another late-model starter??
Any other suggestions, If I am going to spend big money it better be complete bulletproof and reliable.
A couple pics:
A couple pics:
gryphon68- Posts : 51
Re: Starter Problem
Crank Trigger at 28 deg with 10 degrees of start retard in the Digital 7.
Re: Starter Problem
That was gonna be my question too,but w/retard there should'nt have been any kickback
Re: Starter Problem
was your starter flat up aganst the bell houseing?did the bolt holes line up with out cocking the starter to get them started?
reason i am asking is i went to put my starter on last weekend and found some clearance issues.it took me awhile but i fixed the issues and the bolts screwed rite in with out cocking the starter.
Larry T- Posts : 1076
» Starter problem
» starter problem
» Starter problem/ wont shut off
» Starter wiring , with solinoid on starter and fender
» Oil PSI problem
» starter problem
» Oil PSI problem
