starter problem
cturk1010
starter problem Empty starter problem
Post  cturk1010 May 13th 2012, 7:12 am
i have a basicly stock 429 with headers and some other go fun parts but my problem is it starts great when cold but take for a ride and it gets warm the thing barely turns over and by warm i mean anything above 150 on the temp guage i put in a biger battery and tryed a different stock starter and same thing i am thinking that maybe the starter is getting to hot with the header about 1/2 inch from the starter looking at the mini starter from dbelectric and was thinking this may help but what do you think is ther something i may be missing why it does this
cturk1010
starter problem Empty Re: starter problem
Post  cool40 May 13th 2012, 12:12 pm
check all your cables over and the ends.also make sure the ground is on the engine block from the battery and a ground to the body from the engine. Smile
Post  dfree383 May 13th 2012, 12:33 pm
Also try some head wrap on the starter
Post  cturk1010 May 13th 2012, 3:08 pm
i am grounded to the block from battery then to frame replaced all cables that looked bad i will try heat shield for starter see if that helps
cturk1010
Post  LivermoreDave May 13th 2012, 4:49 pm
Ignition timing ?
LivermoreDave
Post  cturk1010 May 13th 2012, 7:03 pm
i am going to play with that a bit more i just put a new cam in and it did this before new cam and i have not cheacked timing yet still not sure what the best timing would be i just set it to run and break in the cam
cturk1010
Post  dave d May 13th 2012, 7:28 pm
Mine does the samething,BUT it's ME adjusting the timing advanced to get quicker et. when i do this it will start cold but it struggles and a bear when it's warmed up. Hope this helps
dave d
dave d
Post  powerstrokeace May 13th 2012, 8:33 pm
the only starter I us is a Tilton super starter....
Ace
powerstrokeace
powerstrokeace
Post  466cj May 14th 2012, 12:31 am
Sounds like heat soak. I'd try a heat shield and wrap the header tube where it comes close to the starter. Heat reduces the magnetic field which reduces how much torque the starter can generate. If the heat shield and header wrap don't do it then the late model starter like you mentioned would be a good idea provided the transmission is an automatic.
Of course you do need to make sure your timing is not too advanced too...
466cj
