Ordering Push-rods
Ordering Push-rods Empty Ordering Push-rods
Post  ROAD RAGE May 15th 2010, 8:00 pm
Well, before I order my push-rods, would like a few opinions,
P51 headed 528, Mechanical flat tappet. Roller rockers.
Is what I did was, kept the push-rod as close to perpendicular as possible to the rocker at mid-lift.
Started around 9.100 on the intake, wound up at 9.200 and it was perfectly centered with the roller not making much of a mark.(maybe .125 or a little less sweep at top of valve). Am I correct on the intake side? (9.200)
Now the exh, It took a little longer to get it, What I hope is wright, Everything looks good at mid-lift but it's off a little to the intake side on the valve tip, about the same sweep as the intake, came up with 9.400 on it.
So does this sound about wright???? What length are You guys running P51's on a standard block.
Thanks.
ROAD RAGE
ROAD RAGE
Ordering Push-rods Empty Re: Ordering Push-rods
Post  Lem Evans May 15th 2010, 8:51 pm
the standard p51 package we sell is 9.100"/9.300' but, can change depending on the roker arm used and the base circle of the cam.
Post  ROAD RAGE May 16th 2010, 3:10 am
Thanks Lem,
I'll double check my masurement.
ROAD RAGE
ROAD RAGE
