302 question
302 question
I have an 86gt vert with a 302, had to remove the intake and valve covers today to fix an oil leak. When I pulled the intake the runners were carboned up pretty good so I'm going to clean all that up. My question is how to get it out of the headit only goes about 1\2" into the head I was thinking carb cleaner and a scotchbrite pad with a shop vac sucking everything out. Anybody have any other ideas? And any cheap upgrades I should do now?
curiousgeorge- Posts : 191
Re: 302 question
Cleaning out the carbon will help a lot, also replace the valve guide seals and springs while you're in there if the budget allows.
torkair- Posts : 404
Re: 302 question
I hadn't planed on going that far but I'll have to check into it, saving money for the interior right now. Gonna start polishing on the intake tonite.
Re: 302 question
If they are carboned up that bad, maybe better to pull them and clean them right.
Re: 302 question
I don't think it's bad enough to have to pull them, It's just a light film that goes about 1/2" into the head and from there to the valve it's good. The lower intake is a little worse and the upper needs some tlc too. If I go very far I've got a 429 sitting in the corner. But for now it's just gonna be a driver.
Re: 302 question
Keep the nozzle of your shop vac as close as possible to the cutter while you're chompin on the carbon.
» Cam Question..
» Fabbed Motor Plates?
» 460 4x4 question
» Jon, Question on 6.0
» Cam Question..
» 460 4x4 question
