kaase oil pump-who sells them
lx545
kaase oil pump-who sells them Empty kaase oil pump-who sells them
Post  lx545 August 20th 2009, 8:16 pm
who here can get me the best price on the kaase oil pump thanks JJ
lx545
kaase oil pump-who sells them Empty Re: kaase oil pump-who sells them
Post  bruno August 20th 2009, 8:25 pm
JJ give Lem Evans a call ..thats were i got mine from ..his number is scrolling across the banner above Very Happy
http://WWW.CKRME.COM
Post  lx545 August 20th 2009, 8:48 pm
k will do thanks- JJ
lx545
Post  bbf-falcon August 21st 2009, 12:08 am
WARNING- Install oilpressure line on back of engine before pumping up and priming oil system. Could pump pan dry before releasing trigger on drill. affraid What a Face Laughing Laughing Laughing
Post  69F100 August 21st 2009, 5:39 pm
did it on mine it had 80 psi I tried to put my finger over it that don't work make a mess oil down the back of the engine and it had even been fired up What a Face
Post  lx545 August 21st 2009, 7:53 pm
i will be sure and do that ive left the plug out by the timing cover before lol
lx545
Post  4thHorseman August 27th 2009, 6:15 pm
That pump rocks. I tried a modded melling but had pressure fluctuation issues. Swapped it out and problem is gone. Good, steady pressure all thru a pass and even after lifting.
4thHorseman
4thHorseman
Post  studly August 27th 2009, 6:39 pm
i have had good luck with the titan oil pumps just make sure you have enough oil they will pump it all out of the pan if the pressure is set to high
studly
studly
