dropped valve?
new2460
dropped valve? Empty dropped valve?
Post  new2460 May 20th 2010, 5:15 pm
what would cause a valve to drop? my brother was reving it but not hard maybe 3500rpm's. next thing bam bam bam. shut it off pull heads and dropped an exhaust valve. the valve head broke off. trying to figure why? .030 460 solid roller cam(low .600 lift) iron cj heads performer rpm intake 850 holley. any ideas? block is junk. it has a big ol hole in it. thanks
new2460
dropped valve? Empty Re: dropped valve?
Post  the Coug May 20th 2010, 5:23 pm
two piece valves do that all the time.... just the heads break off....
Post  cool40 May 20th 2010, 10:07 pm
you could probly fix the block.sorry about your luck. Sad
Post  69F100 May 20th 2010, 10:15 pm
X2 on what Randy said
here what happen to me when the valve head pops off this is the piston out of my 351c with 2.19 1.72 valves took the block out and 1 head going down the road turning 2500 rpms
dropped valve? RANGERCAGE005-2
dropped valve? RANGERCAGE003-2
Post  billandlori May 20th 2010, 10:27 pm
Yikes!!! That looks painfull.
Bill
dropped valve? Empty i think they were manley
Post  new2460 May 20th 2010, 10:37 pm
valves. i know they were ss valves. are they 2 piece? block is wasted half the cylinder wall is gone. my next ? is a buddy said we can have his back up motor. hyper pistons, .030, balanced, stock rods w/ arp bolts, c460 hydraulic cam. what would are compression be with 72cc heads? the pistons are sealed power h535 flat tops w 2 valve reliefs. would it be to high? we just want to get back to the track. thanks
new2460
Post  the Coug May 20th 2010, 10:46 pm
personally before I use Hyper u junktics I would build a new short block..... but thats your choice...
dropped valve? Empty money is tight
Post  new2460 May 20th 2010, 10:52 pm
money is tight rite now and we can get it for free and just put are top end on it.
new2460
Post  the Coug May 20th 2010, 10:55 pm
the question is how bad are your CJ heads? are they fixable?
Post  cool40 May 20th 2010, 11:25 pm
hell yea!,free stuff always works.what if you drop another valve in this free short block?is it still free?i'd want to know before i used it. Laughing
Post  95lightiningguy May 20th 2010, 11:30 pm
Is the rotating assembly except for the one piston not any good? if it is I would find another block replace piston an fix heads. Just my .02c. Sad
95lightiningguy
95lightiningguy
Post  cool40 May 20th 2010, 11:36 pm
could you not sleeve the block?i'v done it but did'nt have half gone. Laughing
dropped valve? Empty block is junk
Post  new2460 May 21st 2010, 12:16 pm
im pretty sure the block is junk. the heads dont look that bad. im sure it will need a new seat and obviosly a new intake and exhaust valve. the chamber doesnt look that bad either. ive seen alot worse that were able to be fixed plus i allready have a set of dove heads that are ported w/ big valves. thanks
new2460
Post  the Coug May 21st 2010, 12:47 pm
Hopefully they are 1 piece and not the 2 piece.....
dropped valve? Empty ferrera valves
Post  new2460 May 21st 2010, 3:37 pm
the ones in the doves are ferrera(spell check). thanks
new2460
Post  c.evans May 22nd 2010, 12:34 am
I hope you know that there are three different series or "grades" of Ferrea stainless steel valves. The PN is laser etched in the stem up at the tip of the valve. Let us know what the number is please.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  nuclearcobra May 27th 2010, 6:51 pm
Wow i sure hope my milodon megaflo valves i just got for my c8 heads were a good choice.
nuclearcobra
nuclearcobra
