Ideal oil pressure ?? Vacuum ??
feetfirst
Guys, what oil pressure would you recommend?
I have an external peterson pump which is of course fully adjustable.
A460 block, with 0.070 restrictor.
515 Ci with 3.85 stroke, 0.0033+ mains, and 0.0025 + on GRP rods, 10-30 oil, and spinning to 8000 and change.
What about vacuum pump? I have the pin end a little loose, at 0.0011-12.....
And yes, I fired it last nite.........and I think I have created a MONSTER.....
Thanks.
Thanks.
feetfirst- Posts : 139
Re: Ideal oil pressure ?? Vacuum ??
Idel oil pressure depends on alot of different things, oil used, clearances, application Ect., I've heard it said many times, by quite a few Pros, you only need enough to make it live......... but from what your describing 55-60 lbs should be fine while gettin' it.
as Far As vacuum Kaase seem to think any thing more than 10 will kill a BBF. with a wet system.
I should add, Im running 0.043/0.043 ring pack, with total seal golds for oil rings....
We shoot for 60psi oil pressure at idle with our peterson pump and about 6" vacuum. Just enough to dry the engine out. That is about the only reason we run a vacuum pump on the turbo car. When we ran nitrous we never went over about 8-9", it didn't make any more power in our app on the dyno but every engine is different.
whatbumper- Posts : 3024
dfree383 wrote:Idel oil pressure depends on alot of different things, oil used, clearances, application Ect., I've heard it said many times, by quite a few Pros, you only need enough to make it live......... but from what your describing 55-60 lbs should be fine while gettin' it.
Around here everyone runs SB's, with similar clearances, but 0-5 or 0-10 oil, spinning 9500+ with 50-60 oil pressure as well......
I have seen the 10 inch vacuum rule as well, and will keep it under that for now.
I think I have created a MONSTER..... Shocked Shocked Shocked
Your car was a bad little car before!
'65 T-BOLT- Posts : 1464
'65 T-BOLT wrote:I think I have created a MONSTER..... Shocked Shocked Shocked
Yes, it worked really well... This is a whole new A-headed combo with a lot more power....
We will find out how it works on Saturday.....I'll see if I can get some video up if it runs some decent #s...
it should run some decent numbers! unless the old combo was 1/8 mile times. your car just works really well!
feetfirst wrote:'65 T-BOLT wrote:I think I have created a MONSTER..... Shocked Shocked Shocked
Will you be running at GB?
Bill
billandlori- Posts : 2081
I run an A460 block, .060 restrictor, loose clearances, 20-50 oil, wet sump deal with an Aviaid external pump, 1.5 section spur gear deal. Hot idle is 55ish, 75 with the touch of the throttle. Cold its about 80 at idle.
You did end up with a glide correct?
Bill
At TMP.....I was "suppose" to run at GB last weekend, but ran out of hours....
richter69 wrote:I run an A460 block, .060 restrictor, loose clearances, 20-50 oil, wet sump deal with an Aviaid external pump, 1.5 section spur gear deal. Hot idle is 55ish, 75 with the touch of the throttle. Cold its about 80 at idle.
Yes, a superglide..
if you have'nt ran the glide yet you'll like it fo sho.
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Can you use transbrake to get a ideal when reading plugs?
» when do you use a vacuum pump?
» Mild (less than ideal) 466 chassis dyno results, guesses for conversion to flywheel horspower
» max vac on dry sump?
